Hi, Yorik blog reads...
"This is a simple interface to manage the different levels (Floors currently) of your document. At the moment you can only do basic things such as changing their properties and add or remove levels, but the intent here is to add more dependent functionality to levels, like WP proxies, which would allow neat things like, upon double-clicking a level, hide all other levels, and set you in a configured view (for example a top view above the level plan). This would mimmick quite well how other BIM apps work, where you can isolate a particular level to only work in it."
This is a feature I almost want to experiment with my limited python knowledge + frankenstein way of combining WPproxy+ArchSectionPlane+CutView ....probably another experiment of weeks/months that a programmer done it in few tens of minutes
Glad it is in a To-Do-List
The Level / Floor Object maybe the most wanted feature, currently it seems Bind to Vertical Axes, Define a Working Plane for Each Level... does not works. Hope to see something like - Level/Floor placement changes, objects in Level/Floor changes altogether...(My frankenstein way experiment is to use Axis + Expressionsss + Sketch/MapMode/ObjectXYZ, very unhandy!)
Thanks and hope to see more features!
Btw, there is error message after OK for the level manager, see screenshot.
- Screenshot from 2018-04-03 07-23-25.png (169.24 KiB) Viewed 7326 times
- Screenshot from 2018-04-03 07-24-00.png (174.79 KiB) Viewed 7326 times
OS: Linux
Version: 0.17.13483 (Git) AppImage
Build type: None
Hash: 0ac32464e45fa9648cdaf702ebda06650dabe9dc
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
Locale: English/HongKong (en_HK)
