Sketcher: Bezier curves
microelly2
Re: Sketcher: Bezier curves
Postby microelly2 » Sat Apr 21, 2018 3:49 pm
microelly2 wrote:
Sat Apr 21, 2018 3:11 pm
abdullah wrote:
Sat Apr 21, 2018 9:59 am
1. I see there is a first sketch which what I think is a periodic B-Spline. Am I right?
2. I see a second sketch with lines, which you are somehow using to modify the sketch with the periodic B-Spline. Could you elaborate a little bit on the "how"?
# -*- coding: utf-8 -*-
#-- create a sketch for a closed bezier curves chain
#-- microelly 2018  0.1
#-- GNU Lesser General Public License (LGPL)
import FreeCAD,FreeCADGui,Sketcher,Part
App = FreeCAD
Gui = FreeCADGui
import numpy as np
import time
import random
class FeaturePython:
	''' basic defs'''
	def __init__(self, obj):
		obj.Proxy = self
		self.Object = obj
	def attach(self, vobj):
		self.Object = vobj.Object
	def claimChildren(self):
		return self.Object.Group
	def __getstate__(self):
		return None
	def __setstate__(self, state):
		return None
class ViewProvider:
	''' basic defs '''
		obj.Proxy = self
		self.Object = obj
		return None
		return None
	def setupContextMenu(self, obj, menu):
		menu.clear()
		action = menu.addAction("MyMethod #1")
		action.triggered.connect(lambda:self.methodA(obj.Object))
		action = menu.addAction("MyMethod #2")
		menu.addSeparator()
		action.triggered.connect(lambda:self.methodB(obj.Object))
		action = menu.addAction("Edit Sketch")
		action.triggered.connect(lambda:self.myedit(obj.Object))
	def myedit(self,obj):
		self.methodB(None)
		Gui.activeDocument().setEdit(obj.Name)
		obj.ViewObject.show()
		self.methodA(None)
	def methodA(self,obj):
		print "my Method A"
		FreeCAD.activeDocument().recompute()
	def methodB(self,obj):
		print "my method B"
	def methodC(self,obj):
		print "my method C"
	def unsetEdit(self,vobj,mode=0):
		self.methodC(None)
	def doubleClicked(self,vobj):
		print "double clicked"
		self.myedit(vobj.Object)
		print "Ende double clicked"
def getNamedConstraint(sketch,name):
	'''get the index of a constraint name'''
	for i,c in enumerate (sketch.Constraints):
		if c.Name==name: return i
	print ('Constraint name "'+name+'" not in ' +sketch.Label)
	raise Exception ('Constraint name "'+name+'" not in ' + sketch.Label)
def clearReportView(name):
	from PySide import QtGui
	mw=Gui.getMainWindow()
	r=mw.findChild(QtGui.QTextEdit, "Report view")
	r.clear()
	import time
	now = time.ctime(int(time.time()))
	App.Console.PrintWarning("Cleared Report view " +str(now)+" by " + name+"\n")
##\endcond
class BezierSketch(FeaturePython):
	'''Sketch Object with Python for Bezier Curve'''
	##\cond
	def __init__(self, obj, icon='/home/thomas/.FreeCAD/Mod/freecad-nurbs/icons/draw.svg'):
		obj.Proxy = self
		self.Type = self.__class__.__name__
		self.obj2 = obj
		self.aa = None
		obj.addProperty("App::PropertyInteger",'polescount',).polescount=12
		obj.addProperty("App::PropertyBool",'init')
		ViewProvider(obj.ViewObject)
	##\endcond
	def execute(proxy,obj):
		obj.Shape=run(obj)
def run(sk):
	gc=sk.GeometryCount
	ap=gc/3
	print ("geometry count, poles, constraints count",gc,ap,sk.ConstraintCount)
	try:
		if sk.init:
			if sk.ConstraintCount <= 150:
				for i in range(ap-1):
					rc=sk.addConstraint(Sketcher.Constraint('Parallel',3*i+3,3*i+2))
#					sk.setVirtualSpace(rc, True)
					sk.solve()
			rc=sk.addConstraint(Sketcher.Constraint('Parallel',gc-1,0))
			sk.init=False
			for i in range(90):
				# must become parameteric, depends on the number sk.polescount
				#if i in [2,3,8,9,15,16,]: # for 3
				# if i in [0,1,6,7,13,14,19,20]: # for 5
				if i in [0,1, 6,7, 13,14, 20,21, 27,28, 34,35, 41,42, 47,48 ]: # for 7
					sk.setDriving(i,False)
					sk.setVirtualSpace(i, True)
			jj=sk.addConstraint(Sketcher.Constraint('Distance',0,10))
			sk.setDriving(jj,False)
			sk.setVirtualSpace(jj, True)
			jj=sk.addConstraint(Sketcher.Constraint('Distance',20,10))
			print "done"
	except: pass
#	for c in range(sk.ConstraintCount):
#		sk.setVirtualSpace(c, True)
	try:
		#poles=[ sk.getPoint(i,1) +FreeCAD.Vector(0,0,random.random()*2000) for i in range(sk.polescount)]
		#poles=[ sk.getPoint(i,1) +FreeCAD.Vector(0,0,0) for i in range(sk.polescount*3)]
		# gleich doppelte Punkte
		poles=[]
		for i in range(sk.polescount*3):
			p=sk.getPoint(i,1)
			if i%3== 0:
				poles += [p,p,p] # corner pole -- multiplicity 3
			else:
				poles += [p] # tangent pole
		cc=Part.BSplineCurve(poles+[poles[0]])
		return cc.toShape()
	except:
		return Part.Shape()
def init_bezierring(sk,count=5,source=None):
	if source <> None:
		ptsa=source.Shape.Wires[0].discretize(count*2*10)
		ptsb=[]
		# read some exact point p for the pole and a approx tangent p2-p, pv-p for the tangent indicators
		for n in range(count):
			p=ptsa[2*n*10]
			p2=p+ (ptsa[2*n*10+1]-p).normalize()*10
			pv=p+((p-p2).normalize())*(10)
			if n==0:
				last=pv
				ptsb += [p,p2]
			else:
				ptsb += [pv,p,p2]
		# the tangent from the first pole
		ptsb += [last]
		# map from xz scan to xy sketch
		pts=[FreeCAD.Vector(p.x,p.z,0) for p in ptsb]
	else: # a generated circle with some noise
		r=100
		pts=[]
		for i in range(count):
			p=FreeCAD.Vector(r*np.cos(2*i*np.pi/count),r*np.sin(2*i*np.pi/count),0)
			p2=FreeCAD.Vector(r*np.cos((2*i+1)*np.pi/count),r*np.sin((2*i+1)*np.pi/count),0)
			p2 += FreeCAD.Vector((0.5-random.random())*0.2*r,(0.5-random.random())*0.2*r)
			pm=(p+p2)*0.5
			pts +=[p,pm,p2]
			if i <> 0: # connect to the last segment with a connector line
				lc=sk.addGeometry(Part.LineSegment(pts[3*i-1],pts[3*i]),False)
				sk.addConstraint(Sketcher.Constraint('Coincident',lb,2,lc,1))
			la=sk.addGeometry(Part.LineSegment(pts[3*i],pts[3*i+1]),False)
			lb=sk.addGeometry(Part.LineSegment(pts[3*i+1],pts[3*i+2]),False)
			if 1: # avoid moving of points
				p2=sk.getPoint(lb,1)
				cc=sk.addConstraint(Sketcher.Constraint('DistanceX',lb,1,p2.x))
				sk.addConstraint(Sketcher.Constraint('DistanceY',lb,1,p2.y))
				sk.renameConstraint(cc, u'aa ' + str(i))
				p2=sk.getPoint(la,1)
				cc=sk.addConstraint(Sketcher.Constraint('DistanceX',la,1,p2.x))
				sk.addConstraint(Sketcher.Constraint('DistanceY',la,1,p2.y))
				sk.renameConstraint(cc, u'bb ' + str(i))
			# blocking does not work (unsolvable by sketcher) why?
#			sk.addConstraint(Sketcher.Constraint('Block',lb))
			sk.addConstraint(Sketcher.Constraint('Coincident',la,2,lb,1))
			if i <> 0: # connect connector line to the new created segment
				sk.addConstraint(Sketcher.Constraint('Coincident',lc,2,la,1))
	# close the figure
	# the last connector
	la=sk.addGeometry(Part.LineSegment(pts[3*i],pts[0]),False)
	sk.renameConstraint(cc, u'cc ' + str(i))
	# connect head and foot
	sk.addConstraint(Sketcher.Constraint('Coincident',lb,2,la,1))
	sk.addConstraint(Sketcher.Constraint('Coincident',la,2,0,1))
def createBezierSketch(name="BezierRing",source=None):
	if source <> None:
		name="Sk_"+source.Label+'_'
	obj = FreeCAD.ActiveDocument.addObject("Sketcher::SketchObjectPython",name)
	BezierSketch(obj)
	obj.polescount=7
	init_bezierring(obj,count=obj.polescount,source=source)
	obj.init=True
	return obj
def createBezierRingSketch(name="BezierRing",source=None):
	return createBezierSketch(name,source)
if __name__ == '__main__':
	createBezierRingSketch()
Edit:
phpBB [video]
abdullah
Postby abdullah » Sat Apr 21, 2018 4:04 pm
Ach so!
So if I give you a python console, you do not actually need a lever and a fulcrum ;)
It is not the way I intend for the Sketcher, as the B-spline/Bezier is not really there, but I must admit really like how you tackled the problem. You are at a level of python+FC knowledge that you could actually write a book about it :)
EDIT: I saw your edit with the B-Spline inside the sketch. When I will consider this further I will come back here to this thread.
Jee-Bee
Postby Jee-Bee » Tue Nov 13, 2018 1:55 pm
I have a question about the usage of the B-spline.
Would it be possible to create the points where the B-spline is crossing(intersecting) against now the that we edit the control points.
I think in method editing the crossing points is more intuitive as editing the control points.
I have created a model in creo. with 4 construction (yellow dots) lines equal spaced and 5 points 4 on the lines and 1 floating above the center point.
The red lines with the points are what i called the crossing/ intersection points. the blue ..-..-..- lines are the lines between the crossing points.
from user perspective i think that the intersection points are more easy to edit than the control points. When editing the dimension (32.92) all control points are moving but the points where i want the model is still there.
DeepSOIC
Postby DeepSOIC » Tue Nov 13, 2018 2:55 pm
yes, it's just a matter of implementing point-on-curve constraint. It requires quite a bit of effort.
abdullah
Postby abdullah » Tue Nov 13, 2018 6:33 pm
There is basically minimum support for B-Spline in GCS. Therefore what we can do with B-splines is very basic. No point on curve. No tangency other than endpoints... seen from another point of view, it is almost a miracle that we have the support we have with the little the solver knows about B-Splines.
At some moment we will hopefully find new momentum to do that "quite a bit of effort" DeepSOIC is talking about.
Postby chrisb » Tue Nov 13, 2018 7:02 pm
Based on an idea of wmayer I have a section in my sketcher document on how to simulate tangents to a B-spline. Perhaps this technique can be refined by automatically splitting the spline.
Jee-Bee
Postby Jee-Bee » Tue Nov 13, 2018 7:16 pm
I hope at some point the solver is powerfull enough that this kind of functionallity is possible...
microelly2
Postby microelly2 » Wed Nov 14, 2018 8:15 am
I use Sketcher only to hold the control points for a Bezier curve and than I calculate the Bezier curve as a shape.
Working with Bezier curves is easier than with BSplines in general
https://youtu.be/zRhb5vDPEWM
https://youtu.be/GPKJVlakQ8Y
https://youtu.be/PPJ55ghd4KE
Jee-Bee
Postby Jee-Bee » Wed Nov 14, 2018 8:34 am
But that's exactly how the spline in the sketcher also works... I want the reversed. not editing the control points(without a clue where the lines are...) but editing some points on the lines without care how and what the control points are.
microelly2
Postby microelly2 » Wed Nov 14, 2018 9:07 am
In case of Bezier curve the control points are on the curve. So when you move the controlpoints the curve always follows them.
