Assembly3 preview
Turro75
Re: Assembly3 preview
Postby Turro75 » Wed May 02, 2018 9:35 pm
Hello Realthunder,
first thank You for your job, needed as "water in the desert"...
just finished reading these 36 pages, nice reading!
I start playing with it , I got partial success, may be following the tips reported along the thread will help me improving the result.let's see.
I wanted to export the assembly as a step, but it doesn't generate any file. I tried making all links and exporting the obj outside assembly, it works but the objects have original placements. any idea?
realthunder
Postby realthunder » Wed May 02, 2018 10:52 pm
I'll work on STEP import/export very soon. But you can already do this now. For any top assembly you want to export, select the assembly, and change its property 'BuildShape' to 'Compound', then go to Part workbench, menu 'Part->Export CAD', and export as STEP file.
dyleks
Postby dyleks » Thu May 03, 2018 5:56 am
easyw-fc wrote:
Thu Apr 26, 2018 10:53 am
realthunder wrote:
Thu Apr 26, 2018 10:37 am
New version released with Part measurement fix. Is this the what you are using? Because there are actually more than one measuring tools in FC. I have also add a toolbar button to refresh existing measurement to sync with current objects.
very nice improvement!
It would be possible to add also an Arc/Circle radius measurement?
https://forum.freecadweb.org/viewtopic. ... 561#p77529
That is a missed measure in Part measurement tools.
That would be very helpful to be able to measure e.g. between two circle centers or edge and circle.
realthunder
Postby realthunder » Thu May 03, 2018 6:47 am
I checked out your manipulator workbench. Very nicely done. You seem to already have very rich measurement tools implemented. Are there anything you want in particular, which can't be done in Python? I think it would be better to have a dedicated workbench for measuring purpose. Part measurement is only for quick one time measuring, as it is not selectable, nor persistent. In fact, there is a Measure workbench in FC source repository, but only contain a python Measurement object. However, it is not a document object, and no Gui view provider either.
easyw-fc
Postby easyw-fc » Thu May 03, 2018 8:00 am
I made Manipulator WB because of the missing of some measurements in main branch... I just like the idea to have the measure of a circle in main branch... many users seem not to add external WBs...
BTW I need to adjust Caliper to be fully compatible with A3 :)
(I have issues on calculation of placement and I have an issue when adding the annotation plane in measuring)
<asm3.gui> 6.174 - gui.py(53):
  File "C:\FreeCAD-asm3\Ext\freecad\asm3\FCADLogger.py", line 83, in _catch
    return func(*args,**kargs)
  File "C:\FreeCAD-asm3\Ext\freecad\asm3\gui.py", line 24, in _setElementVisible
    sobj = obj.getSubObject(subname,1)
AttributeError: 'NoneType' object has no attribute 'getSubObject'
Jee-Bee
Postby Jee-Bee » Thu May 03, 2018 8:10 am
Fotr me measuring is a quick tool but i would like so see implemented in FC usebkle in all workbenches. switching between workbenches for one or two measures is time consuming and in the long term annoying...
realthunder
Postby realthunder » Thu May 03, 2018 8:20 am
Right, I may add that in the future.
This is just a warning. I'll fix the code to get rid of it. But it shouldn't affect your operation. Can you elaborate the problem you are having?
easyw-fc
Postby easyw-fc » Thu May 03, 2018 8:29 am
I think I need to fix my placement calculation with A3 before being able to see the real reason of my issue... I will update later
Thx :D
realthunder
Postby realthunder » Thu May 03, 2018 8:55 am
Well, you can create a global toolbar (Tools->Customize) to add whatever commands you use the most.
Screenshot from 2018-05-03 16-51-35.png (67.6 KiB) Viewed 698 times
Jee-Bee
Postby Jee-Bee » Thu May 03, 2018 10:07 am
i know but it different
