Arch Window create Wrong Opening Position Bug?
paullee
Postby paullee » Fri Apr 20, 2018 12:39 pm
Hi, I have been experimenting for days about this - for what situations the opening created by Window on a Wall is shifted somehow :?:
See 1st 2 screen captures - single out 'problem' as follows.
Workflow resulted in Incorrect Opening Position
  1. Make a rectangular Sketch e.g.
  2. Build a wall out of it
  3. Move / rotate the wall to a position as desirable (Not the underlying sketch)
  4. Make a Window/Door "in the air' say 0,0,0 (learned from Yorik to work better on a few cases)
  5. Move the Win/Door (not the underlying sketch) to the wall as desirable
  6. Add the Win/Door to the Walls as Host (used Host property in Win/Door object)
    Now, the opening is found not in Correct position but always shifted somehow :!:
    EDIT: Quite 'arbitrarily', can't find a regular pattern of the 'shift'...
    I think this workflow is quite 'ordinary', just some sketch, translation ...
    Trying to find 'correct' workflow to avoid the 'bug' with following finding.
Workflow with Correct Opening Position (& Limitation in Workflow?)
See 3rd & 4th screen captures.
  3. Move / rotate the Underlying Sketch instead of the Wall Object to a position as desirable
    Opening is in correct position!
    So, it seem need to move its underlying Sketch to move Wall? (This 'limitation' does not apply on the Win/Door underlying sketch)
Anybody has a recommended workflow - the 'inconsistency' in behaviour is some how not quite intuitive - I have yet to further test to see if the above 'workaround' works for all scenario.
Thanks for any idea!
Test_ Arch Door Opening_ A1.png (288.83 KiB) Viewed 840 times
Test_ Arch Door Opening_ A2.png (287.37 KiB) Viewed 840 times
Test_ Arch Door Opening_ 01.png (333.5 KiB) Viewed 840 times
Test_ Arch Door Opening_ 02.png (283.77 KiB) Viewed 840 times
Test_ Arch Door Opening_ 3_ Sketch_ Wall Offseted.fcstd
(14.62 KiB) Downloaded 31 times
paullee
Re: Arch Window create Wrong Opening Position Bug?
Postby paullee » Fri Apr 20, 2018 12:41 pm
Maybe also attach this file -
it contain model in 'correct' worflow and correct opening position.
Test_ Arch Door Opening_ 1.fcstd
(20.47 KiB) Downloaded 31 times
paullee
Postby paullee » Mon Apr 23, 2018 12:37 pm
Playing around the rotation of the door object let me realize it should be the 'origin' of the door subtraction volume being calculated at incorrect disposition?
By rotating the door in steps, the 'loci' of the subtraction volume could be traced / imagined.
phpBB [video]
phpBB [video]
Test_ Arch Door Opening_ 1a_ This Also Fails.fcstd
(30.85 KiB) Downloaded 30 times
paullee
Postby paullee » Mon Apr 23, 2018 1:07 pm
Thickening the wall, then can see the whole subtraction volume...
Interesting ... different in 'length' between a 2mH door and a 1mH window?
Screenshot from 2018-04-23 21-02-53.png (229.1 KiB) Viewed 780 times
Screenshot from 2018-04-23 21-03-09.png (241.48 KiB) Viewed 780 times
Postby Kunda1 » Sun May 06, 2018 10:30 am
@yorik should we open a ticket for this ?
Postby yorik » Mon May 07, 2018 3:03 pm
Okay I could reproduce the problem, indeed there is something wrong in the way the opening is generated:
Screenshot from 2018-05-07 12-01-49.png (128.81 KiB) Viewed 700 times
Will look into this asap
paullee
Postby paullee » Sat Nov 16, 2019 12:38 pm
Before a permanent fix 'local' to ArchWall.py is available ...
... a kind of 'workaround' with Link (and PR of related fixes by @Realthunder) be merged as discussed in a Thread about another topic -
[ Feature / Bug ] - Link of Array Solid Subtraction Do Not Create Openings
Screenshot from 2019-11-16 20-29-38.png (195.27 KiB) Viewed 285 times
