Empty SVG groups grow up the exported files
flachyjoe
Post by flachyjoe »
I notice some SVG files produced by TechDraw have many empty groups : a <g> item without any geometry inside.
ie.
     stroke-linejoin="bevel"
     id="g111675">
    <g
       fill="none"
       stroke="#000000"
       stroke-opacity="1"
       stroke-width="1"
       stroke-linecap="square"
       transform="matrix(1,0,0,1,0,0)"
       font-family=".SF NS Text"
       font-size="45.8611"
       font-weight="400"
       font-style="normal"
       id="g75837" />
    <g
       fill="none"
Such dust can be cleaned with this search RegExp in a text editor :
<g[^<>]*/>
- Flachy Joe -
wandererfan
Re: Empty SVG groups grow up the exported files
Post by wandererfan »
flachyjoe wrote: Mon May 07, 2018 2:01 pm I notice some SVG files produced by TechDraw have many empty groups : a <g> item without any geometry inside.
Not sure we can do much about this. The file is created automagically by the QtSvg module.
ulrich1a
Post by ulrich1a »
The program scour does a good job in optimizing the size of a SVG-file: https://github.com/scour-project/scour
What could be done in FreeCAD, is to open the file and do some cleaning and save the cleaned file automatically.
The other option is to write a SVG-exporter.
Ulrich
flachyjoe
Post by flachyjoe »
I spent a few time to write a cleaner witch remove empty groups and concatenate identical adjacent ones.
When edit with Inkscape for example, we got one group per view. It's really useful.
A improvement will concatenate non-adjacent similar groups.
#!/usr/bin/env python
# -*- coding: utf-8 -*-
#  clean_fc_svg.py
#  Copyright 2019 Florian Foinant <ffw_at_2f2v.fr>
#  This program is free software; you can redistribute it and/or modify
#  it under the terms of the GNU General Public License as published by
#  the Free Software Foundation; either version 2 of the License, or
#  (at your option) any later version.
#  This program is distributed in the hope that it will be useful,
#  but WITHOUT ANY WARRANTY; without even the implied warranty of
#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#  GNU General Public License for more details.
#  You should have received a copy of the GNU General Public License
#  along with this program; if not, write to the Free Software
#  Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston,
#  MA 02110-1301, USA.
def main(args):
	if len(args)!=3 :
		print "Clean a FreeCAD exported SVG file"
		print "Usage : python clean_fc_svg.py input.svg output.svg"
		return 1
	input_svg = open(args[1],'r').read()
	import re
	#remove empty groups
	input_svg = re.sub('<g[^<>]*/>\n ','',input_svg)
	#parse the xml
	import lxml.etree as ET
	ET.register_namespace("svg", "http://www.w3.org/2000/svg")
	parser = ET.XMLParser(remove_blank_text=True)
	root = ET.fromstring(input_svg, parser)
	tree = ET.ElementTree(root)
	#concatenate identical adjacent groups
	last_grp = None
	parent_grp = None
	for grp in root.iter('{http://www.w3.org/2000/svg}g') :
		if len(grp) == 1 :
			if not last_grp is None and cmp(grp.attrib,last_grp.attrib)==0 :
				last_grp.append(grp[0])
				if parent_grp is not None :
					parent_grp.remove(grp)
			else :
				last_grp = grp
		else :
			parent_grp = grp
	#Save the cleaned XML
	tree.write(args[2], encoding='utf8', xml_declaration=True, pretty_print=True)
	return 0
if __name__ == '__main__':
	import sys
	sys.exit(main(sys.argv))
- Flachy Joe -
flachyjoe
Post by flachyjoe »
Updated with the announced improvement :
#  clean_fc_svg.py
def main(args):
	if len(args)!=3 :
		return 1
	try :
	except IOError :
		print "No such file:", args[1]
		return 1
	#parse the xml
	grps = [g for g in root.iter('{http://www.w3.org/2000/svg}g')]
	print 'Start : %i groups' % len(grps)
	#concatenate identical groups and remove empty ones
	parent_grp = root
	empty_count=0
	identic_count=0
	for grp in grps :
		if len(grp) == 0 :
			empty_count += 1
		elif len(grp) == 1 :
			for known in grps :
				if grp != known :
					if cmp(grp.attrib,known.attrib)==0 :
						known.append(grp[0])
						identic_count += 1
						break
				else :
					break
		else :
			parent_grp = grp
	print 'End : %i groups' % len([g for g in root.iter('{http://www.w3.org/2000/svg}g')]), ', %i empty and %i identical removed' % (empty_count, identic_count)
	return 0
	import sys
With my test file :
flachy@joe:~/EnCours/tests FC$ python clean_fc_svg.py test.svg clean.svg
Start : 1136 groups
End : 27 groups , 674 empty and 435 identical removed
- Flachy Joe -
