Re: Another approach to assembly solver (assembly2relaunch)
I use Freecad 0.18.
Don't worry, I use with FreeCAD with pupil to 12 to 15 year's old, and 3D printer for project, and program with Arduino.
Best regard.
Best regard.
It will easier to understand in complex assembly.
Best regard.
I noticed the problem and can reproduce it.
It is not intended. Constraints should be visible below both of involved parts. This is a bug, will try to fix it.
kbwbe
PS: Just playing around with fc0.18: solver works. But updating imported parts not. I think i will have to deactivate this function during next next time for users of fc0.17/18
kbwbe
KBWBE
for me the updater is working...
What messages do you get in Report panel?
I'm on
Version: 0.18.13959 (Git)
Hash: 2f18182b6dff87f8857787c854e39ca4d441f993
Python version: 2.7.14
OCC version: 7.2.0
Good to hear you, several items...
1) please find attached two files. fc0.18 assembly and fc0.18 part
The problem was not reported in report panel. I got messages on screen like "constraint xyz is broken" during reimport.
But now, the problem suddenly disappeared. it works. Do not know why.
Perhaps you can try to reproduce the problematic situation. My old fc0.16-toponamer is shurely involved. It is still present.
2) Prefrence page seems not to be clean. There are relicts (in sourcecode and i think compiled resources), which refer to assembly2.
I intend to work few days on file solversystem.py only. This would be a good point, to have a look about prefences-page and perhaps other things, if this would please to you. If you have some suggestions to other parts of the workbench, it will merge them.
When I start FreeCAD, i often still note messages as: "cannot find module a3lib". Grepping the code, there is nothing to find about a3lib anymore! Whats the problem?
much thanks for your appreciated help,
klaus
My system:
OS: Linux Mint 18.3 Sylvia
Version: 0.16.6712 (Git) (Tests done with 0.18-daily 13964)
Build type: None
Branch: releases/FreeCAD-0-16
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
klaus
My system:
Build type: None
- part-1.fcstd
- (13.66 KiB) Downloaded 115 times
- asm-1.fcstd
- (8.3 KiB) Downloaded 140 times
KBWBE
Find attached new version.
Improvements:
- Solver warns if constraints are not solvable and does not mismatch assembly
- removed some unused old stuff
- small errors fixed.
Next:
- Undo for solving actions
Solver warning looks like:
EDIT: FOR TESTING DO ALWAYS A FRESH ASSEMBLY. DATASTRUCTURE IS CHANGING MUCH. ASSEMBLIES DONE WITH VERSIONS BEFORE WILL SHOW ERRORS AND WILL NOT OPEN CORRECTLY.
kbwbe
Improvements:
Next:
kbwbe
- a2plus-2018-06-19-01.zip
- (556.95 KiB) Downloaded 109 times
KBWBE
Did some test more.
In some usecases, i got the message that the constraints where not to be solvable. But they where correct.
Problem is: The required accuracy could not be reached by solver within the maximum solver steps.
When i reduced the required accuracy, it worked.
I will think about a better way. ( I have to improve convergence of calculations )
kbwbe
kbwbe
KBWBE
Great! really impressive.
testing on realthunder branch, no big issues so far.
One question:
how to do a parallel/angled plane constraints?
Regards
One question:
Regards
@Turro75
parallel/angled constraint is not implemented at moment. I will add soon. In theory it can be implemented adding one new constraint.
First, I will split it up:
1) Parallel constraint: Very easy as only to align one axis. (I will add it shortly in next versions)
2) Angled constraint: Have to think about implementation of additional rotation axis. (will need a bit more time)
Your test where on RealThunder's branch. Yeah! Perhaps it is possible to use his toponaming. (If he will allow! )
KBWBE
