How to create a hole?
micksulley
Postby micksulley » Mon Jul 02, 2018 2:40 pm
OS: Linux Mint 18.3 Sylvia
Version: 0.18.13959 (Git) AppImage
Build type: None
Hash: 2f18182b6dff87f8857787c854e39ca4d441f993
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.2.0
I'm sure I must be missing something, but I have followed the instructions in the manual and can't get it to work.
I want to create a plate with a matrix of holes, evenly spaced, but I am getting stuck creating the first hole.
PartDesign -
Sketch rectangle, close sketch, pad to create plate.
New sketch with just a circle
Select the circle sketch then select the Hole icon
accept default values and OK
I can now see the circle on the bottom face, but it is not a hole. From the notes at the bottom of the page in the manual I need to change teh Revered property, but I have tried this both ways and it makes no difference.
I have attached my file, can you tell me where I am going wrong please?
Thanks
Mick
HoleTest.fcstd
(13.05 KiB) Downloaded 31 times
Re: How to create a hole?
Postby chrisb » Mon Jul 02, 2018 2:58 pm
The hole doesn't seem to work, when the sketch is attached to the principal plane. It works though if you attach it to the face.
Is this a bug that should be reported?
Postby chrisb » Mon Jul 02, 2018 3:01 pm
The hole doesn't seem to respect the reverse property. If you reverse the Pad instead, the hole works.
meme2704
Postby meme2704 » Mon Jul 02, 2018 3:31 pm
Hi
The hole tool you use is used to drill threaded holes for screws, if you use it, it does not take into account the sketch you have drawn, only its center.
you have to enter the type of net (ISO-Imperial-etc), you will be able to choose the diameter, then the type of cut, the depth 'etc.
As it is a depth, it is always towards negative Z, if your piece is towards the Z plus, there is no material to be pierced.
To make just one hole, use the tool "Pocket that works in both directions, and the hole is the diameter of your sketch
Postby NormandC » Mon Jul 02, 2018 4:32 pm
And it cannot be set in the Hole parameters either, IMO that's the issue that should be reported.
What can be done is to set Sketch001's Map Reversed property to true; but then, the circle's orientation from the XY Plane needs to be reversed in the sketch as well.
"Net" is meaningless here. You probably meant thread. (In French, "filet" has many meanings, among them thread or... fishing net)
You do not need to set a threading profile to a hole, there is a "None" option and it works, provided the normal of the sketch is toward the solid.
micksulley
Postby micksulley » Mon Jul 02, 2018 6:31 pm
Thank you all for your replies. Yes reversing the pad did the trick. This means that my pad is now in negative Z, which seems a bit odd, but from the comments the Reversed property not working is a bug, so it should all be OK when that gets fixed.
I also managed to use the MultiTransform tool as well to generate my matrix of holes. I am impressed with that!
Thanks again
Mick
Postby chrisb » Tue Jul 03, 2018 7:29 am
I have created issue 3524.
meme2704
Postby meme2704 » Tue Jul 03, 2018 8:09 am
yes, I have not re-read before posting, sorry
Postby chrisb » Tue Jul 03, 2018 8:15 am
If a hole can be reversed, do we need a separate reverse for counterbore and countersink? Do we need them optionally on both sides?
meme2704
Postby meme2704 » Tue Jul 03, 2018 8:19 am
good question, it would be wrong to have the milling down the hole :lol:
