PPA OCCT 7.2/7.3 freecad-daily
Somehow I dist-upgraded and ended up with OCCT 7.3 and without freecad-daily.
I managed to reinstall occt 7.2 and freecad-daily, however now I can only install the "-dev" packages of the 7.3 (which will remove the 7.2 and freecad-daily).
Is this situation known or being handled?
Re: PPA OCCT 7.2/7.3 freecad-daily
I've run into the same issue, seems FreeCAD 0.17 has been updated to OCC 7.3 but the daily dev 0.18 is still on 7.2. The OCC installer tries to overwrite one version with the other and fails (tried it both ways). So I think at the moment you can have EITHER the 0.17 stable or the 0.18 daily dev installed but not both (at least not without more advanced Linux magic that I am presently incapable of).
I've run in to the opposite problem(?). A regular Ubuntu update of Stable fell over with:
The following packages have unmet dependencies.
freecad : Depends: libocct-data-exchange-7.3 but it is not installed
Depends: libocct-foundation-7.3 but it is not installed
Depends: libocct-modeling-algorithms-7.3 but it is not installed
Depends: libocct-modeling-data-7.3 but it is not installed
Depends: libocct-ocaf-7.3 but it is not installed
Depends: libocct-visualization-7.3 but it is not installed
E: Unmet dependencies. Try using -f.
Same issue here with Xubuntu 16.04.
That's kkremitzki's work.
https://forum.freecadweb.org/viewtopic. ... 60#p243277
I already mentioned the potential issue here, seems like he didn't read about it.kkremitzki wrote:ping
Looks like it is still in progress the release has been updated but not the daily.
There is a version problem with the release I can fix tonight my time.
"fight the good fight"
https://git.launchpad.net/~freecad-main ... 8d3192ba83
After I update the gitversioning/release branch should the above be
freecad (1:0.17.13525-1ppa1) xenial; urgency=medium
- kkremitzki
Sorry about that, I read about it but only remembered after the upload! It should be fixed already.NormandC wrote: ↑Wed Jul 11, 2018 11:25 am That's kkremitzki's work.
Fixed and well fixed. Nice to have your packages in the PPA!! Thankskkremitzki wrote: ↑Fri Jul 13, 2018 10:34 am Sorry about that, I read about it but only remembered after the upload! It should be fixed already.
Thank you very much for fixing this issue.
