kbwbe
Postby kbwbe » Sat Jul 28, 2018 11:50 pm
manuelkrause wrote:
Sat Jul 28, 2018 9:01 pm
@kbwbe:
ATM I'm testing your latest "solver-stabilization" from this afternoon on our A2plus-Man. I had to rework the Torso and thus used the "Update parts" button. After that I got error messages.
Running the Python command 'a2p_updateImportedParts' failed:
File "/home/manuel/.FreeCAD/Mod/A2plus/a2p_importpart.py", line 307, in Activated
updateImportedParts(doc)
File "/home/manuel/.FreeCAD/Mod/A2plus/a2p_importpart.py", line 299, in updateImportedParts
solversystem.solveConstraints(doc)
File "/home/manuel/.FreeCAD/Mod/A2plus/solversystem.py", line 1063, in solveConstraints
ss.solveSystem(doc)
File "/home/manuel/.FreeCAD/Mod/A2plus/solversystem.py", line 204, in solveSystem
self.loadSystem(doc)
File "/home/manuel/.FreeCAD/Mod/A2plus/solversystem.py", line 124, in loadSystem
Dependency.Create(doc, c, self, rigid1, rigid2)
File "/home/manuel/.FreeCAD/Mod/A2plus/solversystem.py", line 716, in Create
dep2.refPoint = circleEdge2.Curve.Center
'Part.Line' object has no attribute 'Center'
I know from previous discussions in this thread, that updating changed but already assembled parts is dangerous, so I just hope this info helps for some bug-fixing. (In my changes were only non-assembly related objects, but I'm not able to estimate the irrational 'naming changes' within "Part Design" without consistent topology naming.
In a case like shown above, do you have a hint on how to fix the assembly most easily?
Manuel
Hi Manuel,
this is one of the usual FreeCAD problems while editing parts. An edge index, before edit, was pointing to a circle. After editing, indexes are mixed up by FreeCAD and same number is pointing to a line instead of circle, somewhere in random position. At moment, it is not checked by A2plus and you get such errors.
Only solution ATM: delete constraints of parts you want to update. Reconstraint these parts after update. Same problem with Hamish's assembly 2. He tried to catch such things, but it is impossible without topological naming within FreeCAD.
KBWBE
latest release: v0.4.42b, installable via FreeCAD's addon manager
project4
Postby project4 » Sun Jul 29, 2018 5:18 am
kbwbe wrote:
Sat Jul 28, 2018 11:37 pm
project4 wrote:
Sat Jul 28, 2018 5:49 pm
Now I'm really confused since even that simple code doesn't work :shock:
            v0 = Base.Vector(0,0,0)
            v1 = v0.add(Base.Vector(10,10,10))
            v2 = v0.add(Base.Vector(2,2,2))
            a = v2
            a.multiply(1/2)
            FreeCAD.Console.PrintMessage("v0: {}\n".format(v0))
            FreeCAD.Console.PrintMessage("v1: {}\n".format(v1))
            FreeCAD.Console.PrintMessage("v2: {}\n".format(v2))
            FreeCAD.Console.PrintMessage("a: {}\n".format(a))
The output is:
v0: Vector (0.0, 0.0, 0.0)
v1: Vector (10.0, 10.0, 10.0)
v2: Vector (0.0, 0.0, 0.0)
a: Vector (0.0, 0.0, 0.0)
Hi project4, found the problem, see here:
>>> a = v0.add(Base.Vector(2,2,2))
>>> a.multiply(1/2)
>>> a.multiply(1.0/2.0)
Vector (1.0, 1.0, 1.0)
The problem is caused by integer division. 1/2 = 0. Float division: 1.0/2.0 = 0.5
P.S.:
This is a problem too:
a = v2
With a.multiply(1/2), v2 is damaged also, as a is a reference to v2.
This only can be avoided by:
a = Base.Vector(v2) <== de facto a copy operation
now a.multiply(1/2) does not anymore affect v2
Hmm...
You're right about the 1/2 and 0.5 in the multiply.
But it's very strange that the constants are not converted to float automatically...
The "v2 = v0.add(Base.Vector(2,2,2))" resulted in "v2: Vector (0.0, 0.0, 0.0)" after all.
If I change it to (2.0,2.0,2.0) it produces expected results.
I still have no explanation about the calcSpincCenter results:
big-plate_001 - Ref point: Vector (50.0, 150.0, 20.0), new center Vector (50.0, 150.0, 20.0)
big-plate_001 - Ref point: Vector (150.0, 50.0, 20.0), new center Vector (200.0, 200.0, 40.0)
big-plate_001 - Spin center: Vector (200.0, 100.0, 10.0) num of points: 2
Very strange...
project4
Postby project4 » Sun Jul 29, 2018 5:50 am
Hmm...
Very strange...
Ignore the problem... Looks lie I accidentally deleted that line:
            self.spinCenter = newSpinCenter
And printed the self.spinCenter before it was changed...
Now I have proper spinCenter, but don't get to the expected angles yet. Will keep exploring.
project4
Postby project4 » Sun Jul 29, 2018 5:58 am
@kbwbe
You will probably have faster answer than I'll get by myself...
I have the spinCenter point.
I have 2 vectors to 2 refPoints:
# Pseuto-code:
spinCenter = self.spinCenter
v1 = spinCenter.add(dep.refPoint)
v2 = spinCenter.add(foreignDep.refPoint)
How do I get the angle between the 2 vectors?
angle = v1.getAngle(v2)
It's probably don't enough since the v1 and v1 vectors are probably pointing to the refPoints from the zero coordinates.
Probably have to multiply by something, but by what?
I want to find the angle of 2 vectors pointing from the centerPoint.
Thanks.
Turro75
Postby Turro75 » Sun Jul 29, 2018 7:28 am
@kbwbe
# Pseuto-code:
Thanks.
Substract spincenter to both v1 and v2, now you have two vectors which are both starting at origin and keep original angle. So now getangle gives you a reliable value.
As Kbwbe already said be careful on using methods on spincenter as most of them modify spincenter too
project4
Postby project4 » Sun Jul 29, 2018 9:22 am
@kbwbe
# Pseuto-code:
Thanks.
Thanks!
kbwbe
Postby kbwbe » Sun Jul 29, 2018 9:31 am
@kbwbe
# Pseuto-code:
Thanks.
Hi @project4,
hi @turro75,
Turro's explanation is correct. You have to work with vector-differences and extract angles later between them.
This pseudocode makes sense:
# Pseuto-code:
/*Edit: changed order of sub operation to get right direction of vectors*/
v1 = dep.refPoint.sub(spinCenter) #<=== v1 is newly calculated, spinCenter and dep.refPoint stay untouched
v2 = foreignDep.refPoint.sub(spinCenter)#<=== v1 is newly calculated, spinCenter and foreignDep.refPoint stay untouched
angle = v2.getAngle(v1)#<=== angle is returned in radians, but a later rot=FreeCAD.Rotation(axis,angle) takes degrees !!
Calculated angles are always in this range: 0.0 < angle < math.pi
In most cases you have to work with vector.sub(vector) to get relative vectors you are calculating with.
As all vectors within rigid and dependencies are vectors from zero-coordinates to a location. These vectors can be prettily easy handled by global placement operations. Everything in solver is following this principle.
KBWBE
Jee-Bee
Postby Jee-Bee » Sun Jul 29, 2018 10:48 am
Is there a reason that you are working with math and not with numpy. Since numpy is using vectors all the time I expect it should be faster and more easy to use...
kbwbe
Postby kbwbe » Sun Jul 29, 2018 11:02 am
Hi @JeeBee,
i am not really firm to use numpy. Therefore i decided for myself to use FreeCAD's API functions in hope, that they are fast enough as coded in C.
Do you expect a big difference in calculation speed using numpy instead of FreeCAD's API ?
KBWBE
kbwbe
Postby kbwbe » Sun Jul 29, 2018 1:40 pm
Hi @project4,@turro75,@manuelkrause,
Branch "solver-stabilization" has been updated again.
There is a new command "repair-treeview". After deleting an imported part and further undoing this by FreeCAD, the constraints were not grouped under the import parts any more. By using "repair-treeview" they are sorted again to correct place.
I do not know how to start this automatically after "undo", therefore a new command at moment.
@project4: Do you know how to start the "repair-treeview" after undo automatically ?
KBWBE
