appimage
Re: appimage
Recent questions here suggest we should have something like this for windows too.
Re: appimage
Wow, this is a great achievement!triplus wrote:Note that for Conda based AppImage support for delta updates got added:
Is there an alternative to appimage for windows?chrisb wrote:Recent questions here suggest we should have something like this for windows too.
Re: appimage
I'm afraid no. But windows hasn't a package mechanism like Debian based systems with dependencies, so I assumed that the windows version of FreeCAD was already self contained.
Independent of the packaging, what I meant was a more automated update mechanism for FreeCAD.
Re: appimage
With conda we have a packagemanager. Now we only need an alternative to appimage to create bundles... Using a package-manager seems to be too difficult for people who are only interested in freecad.
Re: appimage
There actually is FOSS framework available to achieve something like that. It is called Sparkle (macOS) and WinSparkle (Windows). AppImage approach is similar. There is one problem (in addition to implementing support) as Sparkle doesn't support GitHub (releases API). And therefore we would need to provide download files from HTTPS server.
P.S. I noticed if the AppImage delta update process gets canceled or interrupted (network issues). It will continue from that point on in the next try (and won't start again from scratch).
Re: appimage
Thanks for sharing. Looks good.
I am still not sure how to create daily build with conda. I saw numba does this with updating the build number and uploading automatically to anaconda. I think this could also be done for freecad, but it would be nice to not store more than 10 builds... I am not sure if it's possible to delete packages with anaconda-client in an automatic way.
Re: appimage
To be honest ATM i don't have any experience with Conda and no understanding of the process involved regarding how the Conda packages get build. As for tackling the version information i responded here:
https://forum.freecadweb.org/viewtopic. ... 10#p248955
Re: appimage
Note that i added delta updates support for daily PPA based AppImage two weeks back. PPA wasn't updated and i couldn't test if it works. Therefore i waited with the announcement to do that first. By following the same instructions:
https://forum.freecadweb.org/viewtopic. ... 60#p247818
Updating two weeks old AppImage (22MB):
Updating one day old AppImage (11MB):
P.S. This option will likely prove to be useful for people on a limited bandwidth.
zsync2: Usable data from seed files: 90,275369%
zsync2: used 213237760 local, fetched 22969416
zsync2: Usable data from seed files: 95,236526%
zsync2: used 224956416 local, fetched 11250760
Re: appimage
@triplus can you make a post like this https://forum.freecadweb.org/viewtopic. ... 60#p247818
That I can cut and paste to the releases page (You can use mark-down)
I need to test this, seems ideal.
"fight the good fight"
Re: appimage
Hi @sgrogan
Will do (on Saturday).
