Macro for Spreadsheet Alias setup and Part Family Generation
triplus
Re: Macro for Spreadsheet Alias setup and Part Family Generation
Postby triplus » Tue Dec 06, 2016 5:05 pm
I tested the Cube example and it works as advertised. Closing the info dialog results in some issue printed to the report view.
Beyond that i first needed to understand what it should do and after moving the aliases between columns became a breeze. ;)
HoWil
Postby HoWil » Fri Jan 27, 2017 2:46 pm
Dear pablogil, Dear hatari,
I use your macro in a modified version a lot. I want to share it because I think my modifications do enhance the usability a bit.
The key enhancements are:
* The family- and variable- ranges are found automatically (until first empty cell in row 1 or column A).
* Menu entries were cleand and are switched where necessary..... after "Clearing alias.." opens 'Set alias'. If alias were found at startup the 'from' selection box is set to the found value and "Generate Part-Family" is preselected.
* If no alias were found, column B is set for alias.
* After closing the gui is all relevant information about the family given back in a dict.
Attached you find a screencast showing the new macro in actions.
screen.webm
Demo screencast.
(851.52 KiB) Downloaded 315 times
BR,
HoWil
# ==                                           alias Manager                                                ==
# ABOUT
# version v1.0
# Macro developed for FreeCAD (http://www.freecadweb.org/).
# This macro helps managing aliases inside FreeCAD Spreadsheet workbench. It is able to:
#        - create aliases based on first column (A column)
#        - delete aliases placed on a column
#        - move aliases from one column to other one
#        - create a "part family", that's it, create different files for each column in a range. It will add
#          to the original name a suffix based on first row (1)
# More information might be found on FreeCAD forums: http://forum.freecadweb.org/
# LICENSE
# Original work done by tarihatari (https://github.com/tarihatari/FreeCAD_Macros)
# Improved by Pablo Gil Fernandez
# Copyright (c) 2016 tarihatari & Pablo Gil Fernandez
# This work is licensed under GNU Lesser General Public License (LGPL).
# To view a copy of this license, visit https://www.gnu.org/licenses/lgpl-3.0.html.
__title__   = "alias manager"
__author__  = "Pablo Gil Fernandez"
__version__ = "01.00"
__date__    = "20/11/2016"
__Comment__ = "This macro helps managing aliases inside FreeCAD Spreadsheet workbench. It is able to create, delete, move aliases and create a 'part family' group of files"
__Wiki__ = "https://github.com/pgilfernandez/FreeCAD_AliasManager"
__Help__ = "https://github.com/pgilfernandez/FreeCAD_AliasManager"
__Status__ = "stable"
__Requires__ = "FreeCAD 0.16"
Added features:
* Column and row range are found automatically on startup. The first empty cell in column A will stop the autofind_columnrange. The first empty cell in the first row will stop autofind_rowrange functions.
* The clear function will clear all alias fields in the specified (automatically found) range.
* A dictionary is returned containing the childnames the filenames of the of all children (family-members), their alias/parameters and the column-names.
* A autorun parameter can be set on startup to generate a partfamily in the automatically found range without opening GUI elements.
* A automatically check is done if a alias column is set in the automatically found column-range.
* If a alias is already set: go to family_generation combo-box-entry and change the seleced columns
* If no alias is found in the automatically found region run automatically set_alias combo-box-entry (set alias to first column 'B')
#~ Todo:
#~ #  test if other Spreadsheet-names than 'Spreadsheet' are allowed
from PySide import QtGui, QtCore
from FreeCAD import Gui
import os
import string
import FreeCAD
import FreeCADGui
App = FreeCAD
Gui = FreeCADGui
# ===== Info popup window ================================
class infoPopup(QtGui.QDialog):
    def __init__(self, parent=None):
        self.dialog = None
        self.dialog = QtGui.QDialog()
        self.dialog.resize(360,400)
        self.dialog.setWindowTitle("About...")
        info = QtGui.QTextEdit("<h2>INFORMATION</h2><hr><br>This macro helps managing aliases inside FreeCAD Spreadsheet workbench. It is able to create, delete, move aliases and create a 'part family' group of files.<br><h2>USAGE</h2><hr><ul><li><b>set aliases</b>: based on first column (A column), it will create aliases for the range given. If an alias is already set for any other cell the command won't work, it will be needed to clear them before setting them again.</li><li><b>Clear aliases in range</b>: it will clear all aliases inside the given range of cells (only one column).</li><li><b>Move aliases</b>: it will clear and set aliases <b>from</b> a given column <b>to</b> a new one.</li><li><b>Generate part family</b>: it will create different files for each column in a range. It will add to the original name a suffix based on first row. If an alias is already set for any other cell the command won't work, it will be needed to clear them before running the command.</li></ul><h2>LICENCE</h2><hr>Original work done by <b>tarihatari</b> (<a href='https://github.com/tarihatari/FreeCAD_Macros'>https://github.com/tarihatari/FreeCAD_Macros</a>)<br>Improved by <b>Pablo Gil Fernandez</b><br><br>Copyright (c) 2016 tarihatari & Pablo Gil Fernandez<br><br>This work is licensed under GNU Lesser General Public License (LGPL).<br>To view a copy of this license, visit <a href='https://www.gnu.org/licenses/lgpl-3.0.html'>https://www.gnu.org/licenses/lgpl-3.0.html</a>.<br>")
        info.setReadOnly(True)
        info.setAlignment(QtCore.Qt.AlignLeft | QtCore.Qt.AlignTop)
        okbox = QtGui.QDialogButtonBox(self.dialog)
        okbox.setOrientation(QtCore.Qt.Horizontal)
        okbox.setStandardButtons(QtGui.QDialogButtonBox.Close)
        okbox.setFocus()
        grid2 = QtGui.QGridLayout()
        grid2.setSpacing(10)
        grid2.addWidget(info, 0, 0)
        grid2.addWidget(okbox, 1, 0)
        self.dialog.setLayout(grid2)
        QtCore.QObject.connect(okbox, QtCore.SIGNAL("rejected()"), self.close)
        QtCore.QMetaObject.connectSlotsByName(self.dialog)
        self.dialog.show()
        self.dialog.exec_()
    def close(self):
        self.dialog.close()
# ===== Main code ========================================
# ===== Global variables ==============================================
alphabet_list = list(string.ascii_uppercase)
column_list = []
for i in range(0,26):
    column_list.append(alphabet_list[i])
    for j in range(0,26):
        column_list.append(alphabet_list[i] + alphabet_list[j])
class partfamily():
    def get_family(self):
        family = self.family
        return family
    def get_automatically(self):
        automatically = self.automatically
        return automatically
    def char_range(self, c1, c2):
        """Generates the characters from `c1` to `c2`, inclusive."""
        #~ TODO: This conversion does not work for 'column-name' inputs like 'AB'
        for c in xrange(ord(c1), ord(c2)+1):
            yield str.capitalize(chr(c))
    def aliasManager(self):
        try:
# ===== Variables ==============================================
            mode = self.d1.currentText()
            column_from = self.d2.currentText()
            column_to = self.d3.currentText()
            row_from = self.d4.value()
            row_to = self.d5.value()
# ===== Mode - Set ==============================================
            if mode == "Set aliases":
                for i in range(row_from,row_to+1):
                    cell_from = 'A' + str(i)
                    cell_to = str(column_from) + str(i)
                    App.ActiveDocument.Spreadsheet.setAlias(cell_to, '')
                    App.ActiveDocument.Spreadsheet.setAlias(cell_to, App.ActiveDocument.Spreadsheet.getContents(cell_from))
                FreeCAD.Console.PrintMessage("\nAliases set\n")
# ===== Mode - Clear ==============================================
            elif mode == "Clear aliases in range":
                col_range = []
                for c in self.char_range(str(column_from), str(column_to)):
                    col_range.append(c)
                #~ FreeCAD.Console.PrintMessage(col_range)
                for index in range(len(col_range)):
                        cell = str(col_range[index]) + str(i)
                        #~ FreeCAD.Console.PrintMessage(cell)
                        App. ActiveDocument.Spreadsheet.setAlias(cell, '')
                FreeCAD.Console.PrintMessage("\nAliases cleared\n")
                self.d1.setCurrentIndex(0) # set mode-combobox to 'Set aliases'
                self.d2.setCurrentIndex(1) # set colum "from"- combobox to 'B'
# ===== Mode - Move ==============================================
            elif mode == "Move aliases":
                self.d3.setDisabled(False)
                    cell_reference = 'A'+ str(i)
                    cell_from = column_from + str(i)
                    cell_to = column_to + str(i)
                    App.ActiveDocument.Spreadsheet.setAlias(cell_from, '')
                    App.ActiveDocument.Spreadsheet.setAlias(cell_to, App.ActiveDocument.Spreadsheet.getContents(cell_reference))
                FreeCAD.Console.PrintMessage("\nAliases moved\n")
# ===== Mode - Generate part family ==============================================
            elif mode == "Generate part family":
                doc = FreeCAD.ActiveDocument
                if not doc.FileName:
                    FreeCAD.Console.PrintError('\nMust save project first\n')
                docDir, docFilename = os.path.split(doc.FileName)
                filePrefix = os.path.splitext(docFilename)[0]
                fam_range = []
                    fam_range.append(c)
                #~ FreeCAD.Console.PrintMessage(fam_range)
                for index in range(len(fam_range)):
                    # set aliases
                    alias_values = {} # for storing alias values
                        cell_reference = 'A' + str(i)
                        cell_from = str(fam_range[index-1]) + str(i)
                        cell_to = str(fam_range[index]) + str(i)
                        sfx = str(fam_range[index]) + '1'
                        alias_values[App.ActiveDocument.Spreadsheet.get(cell_reference)] = App.ActiveDocument.Spreadsheet.get(cell_to)
                    # save file
                    suffix = App.ActiveDocument.Spreadsheet.getContents(sfx)
                    filename = filePrefix + '_' + suffix + '.fcstd'
                    filePath = os.path.join(docDir, filename)
                    FreeCAD.Console.PrintMessage("\nSaving view to %s\n" % filePath)
                    App.ActiveDocument.saveCopy(filePath)
                    # Store information about the created family
                    self.family['filenames'].append(filePath)
                    self.family['childnames'].append(suffix)
                    self.family['alias_values'].append(alias_values)
                    self.family['column'].append(fam_range[index])
                FreeCAD.Console.PrintMessage("\nPart family files generated\n")
                #~ FreeCAD.Console.PrintMessage(self.family)
                FreeCAD.Console.PrintMessage("\nClearing alias for reset.\n")
                # Clear lastcol
                    cell_to = str(column_to) + str(i)
                FreeCAD.Console.PrintMessage("\nResetting alias.\n")
                # Reset alias to column A
# ===== If errors ==============================================
            else:
                FreeCAD.Console.PrintError("\nError or 'TODO'\n")
        except:
            FreeCAD.Console.PrintError("\nUnable to complete task\n")
            self.close()
    def close(self):
        self.dialog.hide()
    def autofind_rowrange(self, curr_row=1):
        # Walk through all rows in column A and test if the cell is empty
        values_present = True
        while values_present:
            curr_row += 1
            cellDef = 'A' + str(curr_row)
            try:
                # FreeCAD.Console.PrintMessage(cellDef + " holds : " + App.ActiveDocument.Spreadsheet.getContents(cellDef) + "\n")
                if App.ActiveDocument.Spreadsheet.getContents(cellDef)=='':
                    values_present = False
            except:
        last_filled_row = curr_row -1
        #~ FreeCAD.Console.PrintMessage("\nFound entries up to row "+ str(last_filled_row) + "\n")
        return last_filled_row
    def autofind_columnrange(self):
        # Walk through all columns in row 1 and test if the cell is empty
        curr_column = 0
            curr_column += 1
            cellDef = column_list[curr_column] + '1'
            #~ FreeCAD.Console.PrintMessage(cellDef + " holds : " + App.ActiveDocument.Spreadsheet.getContents(cellDef) + "\n")
            try:
            except:
        last_filled_column = curr_column -1
        #~ FreeCAD.Console.PrintMessage("Found entries up to column "+ str(column_list[last_filled_column] + "\n"))
        return last_filled_column
    def autofind_alias(self, columnrange=[column_list[0], column_list[-1]]):
        # Walk through all columns in row 2 and test if a alias is set
        alias_present = False
        curr_column = 0
        fam_range = []
        for c in self.char_range(columnrange[0], columnrange[-1]):
            fam_range.append(c)
        for ind in range(len(fam_range)):
            cellDef = fam_range[ind] + '2'
            #~ FreeCAD.Console.PrintMessage(cellDef + " holds : " + str(App.ActiveDocument.Spreadsheet.getAlias(cellDef)) + "\n")
            try:
                if App.ActiveDocument.Spreadsheet.getAlias(cellDef) is not None:
                    alias_present = True
                    break
            except:
        if alias_present:
            alias_column = ind
            #~ FreeCAD.Console.PrintMessage("Found alias entries in column "+ str(column_list[alias_column] + "\n"))
        else:
            alias_column = None
            FreeCAD.Console.PrintMessage("Found no alias entries.\n")
        return alias_column
# ===== GUI menu ========================================
    def __init__(self, automatically=False):
        self.automatically = automatically
        infoIcon = ['16 16 3 1',
                '   c None',
                '+  c #444444',
                '.  c #e6e6e6',
        # Hide/show "to column" label and spinbox based on mode type
        def disableWidget(currentIndex):
            if self.d1.currentText() == "Set aliases":
                iN3.hide()
                self.d3.setEnabled(False)
                self.d3.hide()
            elif self.d1.currentText() == "Clear aliases in range":
                iN3.show()
                self.d3.setEnabled(True)
                self.d3.show()
                #~ self.d3.hide()
            else:
                iN3.show()
                self.d3.show()
        family = {}
        family['childnames'] = []
        family['filenames'] = []
        family['alias_values'] = []
        family['column'] = []
        self.family = family
        self.dialog = None
        self.dialog.resize(400,140)
        self.dialog.setWindowTitle("Alias manager")
        iN1 = QtGui.QLabel("mode:")
        iN1.setAlignment(QtCore.Qt.AlignRight | QtCore.Qt.AlignVCenter)
        self.d1 = QtGui.QComboBox()
        self.d1.addItem("Set aliases")
        self.d1.addItem("Clear aliases in range")
        self.d1.addItem("Move aliases")
        self.d1.addItem("Generate part family")
        self.d1.setCurrentIndex(3) # set default item
        self.d1.currentIndexChanged['QString'].connect(disableWidget)
        iN2a = QtGui.QLabel("column:")
        iN2a.setAlignment(QtCore.Qt.AlignRight | QtCore.Qt.AlignVCenter)
        iN2b = QtGui.QLabel("from")
        iN2b.setAlignment(QtCore.Qt.AlignCenter | QtCore.Qt.AlignVCenter)
        self.d2 = QtGui.QComboBox()
        self.d2.addItems(column_list)
        self.d2.setCurrentIndex(1) # set default item
        iN3 = QtGui.QLabel("to")
        iN3.setAlignment(QtCore.Qt.AlignCenter | QtCore.Qt.AlignVCenter)
        iN3.hide() # set initial state hidden
        self.d3 = QtGui.QComboBox()
        self.d3.addItems(column_list)
        self.d3.setCurrentIndex(3) # set default item
        #~ self.d3.setEnabled(False) # set initial state to not editable
        #~ self.d3.hide() # set initial state hidden
        # Find range of columns to use
        try:
            last_filled_column = self.autofind_columnrange()
            if last_filled_column>0:
                self.d3.setCurrentIndex(last_filled_column) # set default item
        except:
            FreeCAD.Console.PrintMessage("Automatically found values for columns cound not be used!\n")
        iN4 = QtGui.QLabel("from row:")
        iN4.setAlignment(QtCore.Qt.AlignRight | QtCore.Qt.AlignVCenter)
        self.d4 = QtGui.QSpinBox()
        self.d4.setValue(2.0) # set default item
        self.d4.setSingleStep(1.0)
        self.d4.setMinimum(1.0)
        iN5 = QtGui.QLabel("to row:")
        iN5.setAlignment(QtCore.Qt.AlignRight | QtCore.Qt.AlignVCenter)
        self.d5 = QtGui.QSpinBox()
        self.d5.setValue(4.0) # set default item
        self.d5.setSingleStep(1.0)
        self.d5.setMinimum(1.0)
        # Find range of rows to use
        try:
            last_filled_row = self.autofind_rowrange()
            if last_filled_row>1:
                self.d4.setValue(2) # set default item
                self.d5.setValue(last_filled_row) # set default item
        except:
            FreeCAD.Console.PrintMessage("Automatically found values for rows cound not be used!\n")
        # Looking for already set alias-columns and set dialog values accordingly
        alias_column =  self.autofind_alias([column_list[0], column_list[last_filled_column]])
        if alias_column is None:
            FreeCAD.Console.PrintMessage("\nNo alias found resetting.\n")
            self.aliasManager()
        else:
            self.d2.setCurrentIndex(alias_column)
        # Info button
        self.d6 = QtGui.QPushButton("")
        self.d6.setFixedWidth(40)
        self.d6.setIcon(QtGui.QIcon(QtGui.QPixmap(infoIcon)))
        self.d6.clicked.connect(self.popup)
        okbox.setStandardButtons(QtGui.QDialogButtonBox.Ok|QtGui.QDialogButtonBox.Close)
        grid = QtGui.QGridLayout()
        grid.setSpacing(10)
        # Mode
        grid.addWidget(self.d1, 0, 0, 1, 3)
        # column, column from
        grid.addWidget(iN2a,    2, 0, 1, 1)
        grid.addWidget(iN2b,    1, 1, 1, 1)
        grid.addWidget(self.d2, 2, 1, 1, 1)
        # column to
        grid.addWidget(iN3,     1, 2, 1, 1)
        grid.addWidget(self.d3, 2, 2, 1, 1)
        # from row
        grid.addWidget(iN4,     3, 0, 1, 1)
        grid.addWidget(self.d4, 3, 1, 1, 1)
        # to row
        grid.addWidget(iN5,     4, 0, 1, 1)
        grid.addWidget(self.d5, 4, 1)
        # + info
        grid.addWidget(self.d6, 6, 0, 1, 1)
        # cancel, OK
        grid.addWidget(okbox,   6, 1, 1, 2)
        self.dialog.setLayout(grid)
        QtCore.QObject.connect(okbox, QtCore.SIGNAL("accepted()"), self.aliasManager)
        if automatically:
            FreeCAD.Console.PrintMessage("\nAutorun selected.\n")
            self.aliasManager()
            self.close()
        else:
            self.dialog.show()
            self.dialog.exec_()
    def popup(self):
        self.dialog2 = infoPopup()
        self.dialog2.exec_()
if __name__ == "__main__":
    # For direct use in the FreeCAD- "Python console" use:
    import aliasManager_popup_HoWil as amp
    p_loc = amp.partfamily()
    fam = p_loc.getfamily()
    p_loc = partfamily()
    FreeCAD.Console.PrintMessage(p_loc.get_family())
aliasManager_popup_HoWil.py
the macro as .py .
(22.41 KiB) Downloaded 60 times
FC_parameter_sweep_demo_v0p03.fcstd
the demo file used in the screecast.
(3.57 KiB) Downloaded 52 times
pablogil
Postby pablogil » Sun Jan 29, 2017 9:18 am
Really cool upgrade!
Now it's handier than ever :D
You should update the "information window" with your credits.
I see you are an experienced coder, do you think it would be possible to get the cells selected in order to use it as reference selection for the script?
Thank you!
HoWil
Postby HoWil » Sun Jan 29, 2017 9:14 pm
pablogil wrote:I see you are an experienced coder, do you think it would be possible to get the cells selected in order to use it as reference selection for the script?
Thx, but I am not :D .
I found that If you select some cells (for instance C1 to C3) and change into the python console and insert:
App.ActiveDocument.Spreadsheet.cells.Content
you will get something like:
'<Cells Count="3">\n    <Cell address="C1" content="1" />\n    <Cell address="C2" content="2" />\n    <Cell address="C3" content="3" />\n</Cells>\n'
These cells are also available when you insert "App.ActiveDocument.Spreadsheet." and press TAB.
This shows me that there has to be a way to access the requested information, but I cant say how to do it to get it in a structured form (without extracting it from the above given text :? ).
BR,
HoWil
silopolis
Postby silopolis » Fri Aug 11, 2017 10:34 am
This is just an *amazing* macro that should absolutely be built in the Spreadsheet workbench !
Now, for my next iteration, I just have to design a parametric master cabinet, build the spreadsheet of all dimensions in the range, and generate all cabinets files in one click... This is fantastic !
Thank you so much guys for this one, it's a game changer for me :-)
Kudos
uribench
Postby uribench » Fri Feb 02, 2018 7:32 pm
I have created yet another macro for manipulating the properties of cells (e.g., alias, units) of a selected spreadsheet.
It supports multiple spreadsheets in the active document, provides automatic discovery of source and target cells, and more.
Check the macro at https://github.com/uribench/SheetProperties
Like others did, the source data for the properties of cells are provided in their own columns. A header line hints on the purpose of the respective columns (e.g., Alias, Units, Value). The macro is tolerant about many aspects of the spreadsheets, including the order of the columns, the row of the headers, empty rows, and more. The included test file shows many of these possibilities.
The following image of the main dialog is included also in the README file with more details:
jruiz
Postby jruiz » Thu Aug 23, 2018 12:49 pm
Hi.
Sometimes it could be useful to give "some structure" to the spreadsheets. So, don't you think it could be very useful to have the option of changing the (default) value of column A for the alias names to any other column one chose?
jruiz
Postby jruiz » Thu Aug 23, 2018 1:34 pm
This is a great macro, congrats.
Suppose one have some simple object parameter values in the same spreadsheet and one uses one column to for object names and subsequent columns for their dimensions. Don't you think it could be very useful to construct the alias names from a combination of the corresponding cell values?
Something like:
A______B _______C ___(alias)
cube
______length_____10___(cubeLength)
______width______12___(cubeWidth)
______height_____14___(cubeHeight)
sphere
______radius______7__ (sphereRadius)
Postby Kunda1 » Thu Aug 23, 2018 3:07 pm
eivindkvedalen wrote:spreadsheet master
@eivindkvedalen needs to be aware of this if he isn't already. .
Postby chrisb » Thu Aug 23, 2018 4:19 pm
Pinging seems to have been unreliable recently. It is best to include the id:
