Compiler: MSVC, version: 19.0.24234.1
prefix: C:/Users/aio/Miniconda3/envs/freecad_py3/Library
datadir: data
docdir: doc
includedir: include
libdir: lib
Boost version: 1.67.0
Found the following Boost libraries:
filesystem
program_options
regex
signals
system
thread
chrono
date_time
atomic
Found Xerces-C: C:/Users/aio/Miniconda3/envs/freecad_py3/Library/lib/xerces-c_3.lib
PyCXX found:
Headers: C:/Users/aio/FreeCADcode/src
Sources: C:/Users/aio/FreeCADcode/src/CXX
Version: 6.2.8
-- Found OCE/OpenCASCADE version: 7.3.0
-- OCE/OpenCASCADE include directory: C:/Users/aio/Miniconda3/envs/freecad_py3/Library/include/opencascade
-- OCE/OpenCASCADE shared libraries directory: C:/Users/aio/Miniconda3/envs/freecad_py3/Library/lib
VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkhdf5;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType;vtkRenderingOpenGL2
Found Netgen: C:/Users/aio/Miniconda3/envs/freecad_py3/Library/cmake
Shiboken2Config: Using default python: .cp36-win_amd64
libshiboken built for Release
-- matplotlib-2.2.2 has been found.
Platform is 64-bit, set -D_OCC64
git
C:/Users/aio/Miniconda3/envs/freecad_py3/Library/src/Build/Version.h written
CMake Warning (dev) at src/Base/CMakeLists.txt:382 (target_link_libraries):
Link library type specifier "debug" is followed by specifier "optimized"
instead of a library name. The first specifier will be ignored.
This warning is for project developers. Use -Wno-dev to suppress it.
area module (for Path Workbench) will be installed to: lib
Could NOT find Doxygen (missing: DOXYGEN_EXECUTABLE)
Configuring done
Generating done
