STEP/IGES color
Re: STEP/IGES color
Postby chrisb » Sat Aug 25, 2018 8:47 am
polymer wrote:
Fri Aug 24, 2018 6:39 pm
Maybe this is usefull: https://www.meusburger.com/EN/US/media/ ... rds_IN.pdf
Is this an internal Meusburger standard or rather a de facto industry standard - or even an ISO?
polymer
Re: STEP/IGES color
Postby polymer » Sat Aug 25, 2018 12:00 pm
This Is an internal Standard or suggestion. I do Not know if there is a standadized colorcode. At my Company we work with an own colorcode, based on the meusburger one.
UR_
Re: STEP/IGES color
Postby UR_ » Mon Oct 08, 2018 5:21 pm
This is the one used in german automotive industrie ;)
https://b2bpapp6.bmw.com/public/en/gdz/ ... ne_CV5.pdf
Please see page 8
polymer
Re: STEP/IGES color
Postby polymer » Tue Oct 09, 2018 3:53 pm
At the moment (raw WIP!) I try to create a new one, because the automotive thing and other Color scheme are not practical.
Here the Color should Show the type of tolerance, and the Color tone how precise it should be.
Shape and position tolerances and Surface qualities are indicated by PMI.
Mainly we work with "Cimatron" and we do not create drawings and only work with 3D files.
Colors are coupled to layers or "sets".
mfg
farbschema_test.FCStd
(582.07 KiB) Downloaded 26 times
iamnotstone
Re: STEP/IGES color
Postby iamnotstone » Fri Jul 05, 2019 2:24 pm
The link above is not reachable now.
I met the same problems. How can I import step file in cmd mode and without color loosing.
I'd notice that there is a TODO flag for this topic in ImportOCAF.cpp
#if 0//TODO
    Gui::ViewProvider* vp = Gui::Application::Instance->getViewProvider(part);
    if (vp && vp->isDerivedFrom(PartGui::ViewProviderPart::getClassTypeId())) {
        if (jt != myColorMap.end()) {
            App::Color color;
            color.r = jt->second.Red();
            color.g = jt->second.Green();
            color.b = jt->second.Blue();
            static_cast<PartGui::ViewProviderPart*>(vp)->ShapeColor.setValue(color);
        partColor = static_cast<PartGui::ViewProviderPart*>(vp)->ShapeColor.getValue();
#endif
What's the situation now ?
easyw-fc
Re: STEP/IGES color
Postby easyw-fc » Fri Jul 05, 2019 3:19 pm
https://www.meusburger.com/FR/FR/media/ ... rds_IN.pdf
iamnotstone
Re: STEP/IGES color
Postby iamnotstone » Sat Jul 06, 2019 2:02 am
Thank you !
