Intersecting pockets
earthcare
Post by earthcare »
Hi
I'm trying to create a right-angle water feed attachment for 3D prototype printing; I've created the housing shape, and added the two sketches for the actual passage through it. (attached)
But to simply pocket the two sketches by the right amount will result in the corner part of the housing having lots of holes - hardly the point. I have no idea how to make these two sketches intersect properly.
Help, please! :? :oops:
Edwin
OS: Linux Mint 18.3
Version: 0.17.13522 (Git) AppImage
Build type: None
Branch: releases/FreeCAD-0-17
Hash: 3bb5ff4e70c0c526f2d9dd69b1004155b2f527f2
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.2.0
RevD-L.fcstd
(87.24 KiB) Downloaded 36 times
TheMarkster
Re: Intersecting pockets
Post by TheMarkster »
You can use a subtractive pipe/sweep to connect the 2 holes together. Just need to draw a path (arc) to connect them.
phpBB [video]
earthcare
Post by earthcare »
Hi TheMarkster
I'm sorry, I don't see what you're doing here.
Bance
Post by Bance »
The wiki page for subtractive pipe/sweep is here....
https://www.freecadweb.org/wiki/PartDes ... activePipe
Essentially, what it does is, use your sketch to move along a path and remove the material it passes through.
There is an additive version as well, which you might have used for the shell of your object.
HTH Steve.
TheMarkster
earthcare wrote: Thu Sep 06, 2018 1:07 am Hi TheMarkster
The more I think on it, a better solution would be use 2 cylinders and a 90 degree torus in a separate body, then cut that body from the first one. It's more complicated, but I think the result is a better model. This would more closely mimic the real world solution of an elbow and 2 sections of pipe. In this video I used additive cylinders and an additive torus, then did the cut. I was going to use subtractive features in order to avoid the extra boolean, but I got a message saying you can't added subtractive features to the empty body, so I decided to go this route instead. The video is a bit longer than I would have liked, but I had to fiddle around getting the placements and rotations like I wanted. I'm not that familiar with this procedure, so it was a learning process for me, too.
phpBB [video]
Edit: Thinking more on it, maybe a more streamlined approach would have been to place the torus first, then pad those faces out.
Edit2: Attached finished FCStd file.
RevD-L2.FCStd
(85.2 KiB) Downloaded 35 times
TheMarkster wrote: Thu Sep 06, 2018 6:57 pm I was going to use subtractive features in order to avoid the extra boolean, but I got a message saying you can't added subtractive features to the empty body
You must not use a new body. If you use the existing the idea with subtractive torus works. Some fine tuning may be necessary, I used expressions in most places, but not everywhere.
RevD-L_cb.fcstd
(116.21 KiB) Downloaded 33 times
TheMarkster
chrisb wrote: Thu Sep 06, 2018 10:38 pm You must not use a new body. If you use the existing the idea with subtractive torus works. Some fine tuning may be necessary, I used expressions in most places, but not everywhere.
Yes, that's much better way than my way, fewer operations and all in the same body.
There are some residues left inside. I have created a new topic concerning refinement of torus. It turned into refinement of primitives.
https://forum.freecadweb.org/viewtopic.php?f=3&t=30755
