Part design sketch plane correct order: XY, YZ, ZX
jruiz
Postby jruiz » Mon Sep 10, 2018 1:46 am
Hi.
In my opinion, it is needed to modify one of the names of the planes (and its "orientation") one can select when making a sketch.
I think that instead of XY, XZ, YZ, the appropriate planes should be XY, YZ and ZX (in this order).
If i, j and k are unit vector along X, Y and Z axes respectively, vector algebra tell us that the following vector multiplications hold:
i x j = k, j x k = i and k x i = j
One of the effects of selecting XZ plane instead of the ZX is that the extrusions of the sketches on the former plane "grow" to the negative direction of the Y axis (by the way, i x k = - j ). Of course it can solved by inverting the extrusion sense, but it has not to be this way.
Regards
I have uploaded some FreeCAD video tutorials to www.youtube.com/yosoyvenezolano
Re: Part design sketch plane correct order: XY, YZ, ZX
Postby chrisb » Mon Sep 10, 2018 2:42 am
That sounds sensible, and I frequently wondered why I had to reverse some directions of attached sketches. This might clarify things. From a systematic view it would be a change from alphabetic order to cyclic order.
However, I am not sure if this is compatible with current models. I am a big friend of clear basics, but if this was changed internally we need a migration concept as well.
Opus
Postby Opus » Mon Sep 10, 2018 3:31 am
The common mnemonic is the right-hand rule: https://en.wikipedia.org/wiki/Right-hand_rule.
Why? It's just a matter of user interface, isn't it?
Extrusion based on sketch built according to the XZ plan is right.
DeepSOIC
Postby DeepSOIC » Mon Sep 10, 2018 8:39 am
current names are consistent with the way sketch axes are mapped to body/model axes.
XY: H_axis = X, V_axis = Y
XZ: H_axis = X, V_axis = Z
YZ: H_axis = Y, V_axis = Z
Now if we change to ZX, the sketch would end up in a very unnatural orientation. Renaming them just for sake of math doesn't help, IMO.
jruiz
Postby jruiz » Mon Sep 10, 2018 8:57 am
... we need a migration concept as well.
I agree...
But I think this way FreeCAD would gain (a little of) math robutness...
jruiz
Postby jruiz » Mon Sep 10, 2018 9:37 am
How about adding the third axis...?
XY: H_axis = X, V_axis = Y, Axis pointing to us Z
XZ: H_axis = X, V_axis = Z, Axis pointing to us -Y
YZ: H_axis = Y, V_axis = Z, Axis pointing to us X
XZ: H_axis = Z, V_axis = X, Axis pointing to us Y
But beyond the viewpoint of the sketches, the effect of extruding a sketch on XZ to -Y is inconsistent with the "other" extrusions modes and it seems to me inconvenient when designing.
DeepSOIC
Postby DeepSOIC » Mon Sep 10, 2018 9:49 am
-Y is incoinsistent with the "other" extrusions modes and it seems to me inconvenient when designing.
I agree, but your proposal replaces this minor inconvenience with a major inconvenience. We can switch XZ to (-X)Z to get rid of both inconveniences, at a cost of another minor inconvenience.
jruiz
Postby jruiz » Mon Sep 10, 2018 10:11 am
... your proposal replaces this minor inconvenience with a major inconvenience...
Are you referring to the work of recoding or to any other mayor inconvenience?
DeepSOIC
Postby DeepSOIC » Mon Sep 10, 2018 10:12 am
jruiz
Postby jruiz » Mon Sep 10, 2018 10:39 am
Well... "very unnatural orientation"... It is question of opinions (in my opinion :) )
I have to put on a balance "unnatural orientation" and and "extruding to a negative axis orientation"...
It would be good to have the option of choosing which of these "schemes" one want to use.
cron
