Sweep not following sweep path
meme2704
Re: Sweep not following sweep path
Post by meme2704 »
@Normand , and salut , ce n'est pas de la french humour
Desolate for the bad traduct, there was no humor
I wanted to say that not mastering V0.18, I worked in V0.16, and I ask more competent to remake it in V0.18 (set to music - mettre en musique, et non pas maître en music)
UR_
Post by UR_ »
I've not pretty much practice with PartDesignWB, still got stuck with PartWB :(
So, I tried to do it myself.
Outlet is a subtractive multisection pipe
FreeCAD 0.18-000055.png (47.97 KiB) Viewed 1285 times
After reopening task panel, second section isn't listed anymore :shock:
FreeCAD 0.18-000056.png (6.82 KiB) Viewed 1285 times
Also tree view didn't clarify cirumstances.
FreeCAD 0.18 -000059.png (104.34 KiB) Viewed 1285 times
So how do we check, which sections are involved?
Thread with Outlet.FCStd
(541.34 KiB) Downloaded 26 times
You can use the Dependency Graph.
UR_
Post by UR_ »
chrisb wrote: Sun Sep 16, 2018 12:38 pm You can use the Dependency Graph.
Nice workaround!
But task panels or property editor should reflect all circumstances of creation at least for further editing.
Also, how would one edit used sweep path segments, after sweep is done. Redoing it from the beginning isn't a comfortable option.
Chris_G
Post by Chris_G »
UR_ wrote: Sun Sep 16, 2018 1:02 pm Also, how would one edit used sweep path segments, after sweep is done. Redoing it from the beginning isn't a comfortable option.
I made a SubLink Editor in CurvesWB.
UR_
Post by UR_ »
Cool! :D
I saw this activity on github, but missed your Howto post. Will try some test, ASAP.
UR_ wrote: Sun Sep 16, 2018 1:02 pm But task panels or property editor should reflect all circumstances of creation at least for further editing.
Of course they should! I think there is a ticket, but you might check.
Post by NormandC »
meme2704 wrote: Sun Sep 16, 2018 5:54 am mettre en musique
As I wrote, even in French, this expression is meaningless to me. Just like about 50% of what you write (if not more) because you make heavy use of regional idioms that are uncommon in Québec. I always try to communicate in international French but you obviously don't.
Post by NormandC »
That is just one of many usability issues with PartDesign, unfortunately, this workbench has been orphaned for a year now. Occasionally a developer will create a commit for this workbench, but there is no longer someone dedicated to its development.
chrisb wrote: Sun Sep 16, 2018 1:51 pm Of course they should! I think there is a ticket, but you might check.
I just scanned the tracker, I didn't find any (unless it was reported in the wrong project). There's issue #3297 that you reported but it's not completely related to what's discussed here.
freecad-heini-1
Post by freecad-heini-1 »
NormandC wrote: Sun Sep 16, 2018 2:16 pm That is just one of many usability issues with PartDesign, unfortunately, this workbench has been orphaned for a year now. Occasionally a developer will create a commit for this workbench, but there is no longer someone dedicated to its development.
Sad, but true. :shock: :oops: :cry:
