Python3 and Qt5 Compatible Addon Macros (in preparation for 0.18)
Postby Kunda1 » Fri Aug 31, 2018 3:57 pm
Objective
A forum thread to track migration of 3rd-party FreeCAD-Addons to Py3/Qt5
Feedback kindly requested from all authors/testers of said Macros to help populate this list.
The List
       Macro                                    Py3      Qt5
├── apothemBasedPrism.py                        Pass	 Pass
├── CartoucheFC.py                              Error     x
├── Conversion
│   └── DeepCopy.FCMacro                        Error     x
├── FCCamera.FCMacro                            Pass     Pass
├── FCRotateViewAbsolute.FCMacro		Pass     Pass
├── FEM
│   └── ExportFem.FCMacro                       x         x
├── Foto.FCMacro                                Error     x
├── GenevaWheelGUI.py                           Pass     Pass
├── makecamera2dview.py                         Error     x
├── myMacroDir
│   ├── __init__.py
│   └── myMacro.py
├── ObjectCreation
│   ├── Airfoil_Import_and_Scale.FCMacro        Error     x
│   ├── Draft_Circle_3_Points.FCMacro           Error     x
│   ├── Draft_Circle_3_Points_3D.FCMacro        Pass     Pass
│   ├── Ellipse-Center+2Points.FCMacro          Error     x
│   ├── GeodesicDome.FCMacro                    Error     x
│   ├── HalfHull.FCMacro                        Error     x
│   ├── HyperbolaCreater.FCMacro                Pass     Pass
│   ├── Macro_FCCircularText.FCMacro            Pass     Pass
│   ├── MakeCircle3Points.FCMacro               Error     x
│   ├── ParabolaCreater.FCMacro                 Pass	 Pass
│   └── ScrewMaker.FCMacro                      Error     x
├── ParametricObjectCreation
│   └── Rectellipse.FCMacro                     Pass     Pass
├── PureGui
│   └── ViewRotation.FCMacro                    Error     x
├── Sketcher
│   └── SketcherClipView.FCMacro                x         x
├── SolidSweep.FCMacro                          Error     x
├── TechDraw
│   ├── TechDrawSymbolsLibrary.FCMacro          x         x
│   └── TechDrawViewSet.FCMacro                 x         x
│   └── LasercutterSVGExport.FCMacro            Pass      Pass
├── unfoldBox.py                                Error     x
├── unrollRuledSurface.py                       Error     x
├── Utility
│  ├── ForceRecompute.FCMacro                   Pass     Pass
│  ├── HighlightCommon.FCMacro                  Error     x
│  ├── HighlightDifference.FCMacro              Error     x
│  ├── MeasureCircle.FCMacro                    Pass     Pass
│  ├── MessageBox.FCMacro                       Pass     Pass
│  └── SelectVisible.FCMacro                    Pass     Pass
└── ExpandTreeItem.FCMacro			Pass	 Pass
Testing
Very quick way to start testing is using the 0.18dev Py3/At5 builds conveniently added by our friend @sgrogan Background
One of the objectives for 0.18 release is that it will be py3 and Qt5 compatible
This are ongoing efforts to make this happen:
issue #995: Python3 compatibility (Ongoing)
issue #2986: Port from Qt4 to Qt5 (Ongoing)
https://github.com/looooo/FreeCAD/issues/8
https://forum.freecadweb.org/viewtopic.php?f=10&t=7713 "PyCXX upgrade" (from 2014)
https://forum.freecadweb.org/viewtopic.php?f=10&t=12534 "Porting to python3" (Active thread)
https://github.com/FreeCAD/FreeCAD-addons/issues/93
Related
FC Workbench Py3/Qt5 Tracker https://forum.freecadweb.org/viewtopic.php?f=10&t=30624
Note: this post will be actively updated
Re: Python3 and Qt5 Compatible Addon Macros (in preparation for 0.18)
Postby Kunda1 » Sun Sep 02, 2018 7:29 pm
chrisb wrote:ping
Hi @chrisb care to move this thread under the Python scripting and macros subforum ? Thanks!
Postby chrisb » Sun Sep 02, 2018 9:31 pm
Done.
Postby Kunda1 » Mon Sep 03, 2018 11:07 am
Thanks!
galou_breizh
Postby galou_breizh » Mon Sep 17, 2018 6:35 am
The List
I guess the 'x' represents a non-compatible macro. Am I right? It looks that there is a lot of work to be done!
Gaël
Postby Kunda1 » Mon Sep 17, 2018 12:18 pm
x represents macros that haven't been tested or are not compatible. Either one
Postby Kunda1 » Tue Oct 30, 2018 8:37 pm
This thread needs to get a little more love
Syres
Postby Syres » Tue Jan 15, 2019 5:15 pm
@Kunda1, I can spare some testing time in the next couple of days, any fixes must be classed as a bonus as it's not my specialist area. Is the list still as it was on 31st August 2018, if so, there's a lot to go at, something in the region of 140?!
Would some polite 'pinging' of macro authors be out of order at this stage in proceedings?
Postby Kunda1 » Tue Jan 15, 2019 7:31 pm
Awesome! Yes please!
Yes sir. If you could report your results I'll be happy to track them here!
Syres
Postby Syres » Wed Jan 16, 2019 2:44 pm
This is today's update. @Kunda1, firstly I'm sure you're aware that The List is significantly smaller than the complete list of macros in the AddOnManager so it may appear as though I've tested quite a few, there's many more that require input.
I'm not happy with the resulting text file as I've made your neat tree appalling to read so I also attached a RTF file with some colour to hopefully assist. If you want a different format (bearing in mind I'm using Msoft Office) please let me know.
I'll continue tomorrow as promised.
Macros_WIP.txt
(7.8 KiB) Downloaded 39 times
Macros_WIP.rtf
(52.09 KiB) Downloaded 36 times
