Bug submission guidelines
Re: Bug submission guidelines
Postby chrisb » Tue Oct 02, 2018 10:35 pm
Kunda1 wrote:
Tue Oct 02, 2018 10:23 pm
and I still think bolded text is a good way to go.
... whatever helps to improve awareness.
sgrogan
Postby sgrogan » Tue Oct 02, 2018 10:40 pm
chrisb wrote:
Tue Oct 02, 2018 9:59 pm
2. Discuss the problem on the forum first!
Maybe we could add an why? link?
I don't know the words, but, "help us triage your bug so it gets fixed. Developer time is precious" etc.?
Postby Kunda1 » Mon Oct 08, 2018 2:27 pm
I think this is also a valid request.
Do we have consensus on what I'm proposing in https://forum.freecadweb.org/viewtopic. ... 36#p259976
Postby NormandC » Mon Oct 08, 2018 6:34 pm
Fine with me.
Postby chrisb » Mon Oct 08, 2018 8:18 pm
Fine with me.
Me too.
sgrogan
Postby sgrogan » Mon Oct 08, 2018 8:35 pm
I would tweak #2 as suggested by chrisb. Even if the user is sure, we want to test on other OS/Distros to refine the bug report.
ooveif9
Postby ooveif9 » Sat Aug 03, 2019 5:45 pm
yorik wrote:
Sun Dec 29, 2013 9:48 pm
1. Make sure that what you found is a bug. The definition of a bug is this: Something that is not working, but for which you are sure that it should be working (for example it worked in the past, or it is advertised on the FreeCAD documentation wiki). Otherwise, it might be simply that what you want is not implemented, or maybe you are doing something wrong.
Please clarify your bug definition. If FreeCAD crashes because I do something wrong, is that a bug or not? Should it be reported? Thanks.
GeneFC
Postby GeneFC » Sat Aug 03, 2019 9:25 pm
Following the directions in the first post of this topic is still the correct method for "bugs".
If you get to the third box, go ahead and create a topic in the Help fourm. The responders will either help find your error or will agree that the crash is really a bug. Don't go straight to the Mantis tracker before discussing on the forum.
A crash should never happen, whether due to user error or a bug. But of course crashes do happen because it is very difficult to predict every sort of error that a user might make.
Gene
Postby chrisb » Sat Aug 03, 2019 10:08 pm
Proposal for point 2:
2. Discuss the problem on the forum first! This should be done before creating a ticket in the bugtracker, for several reasons: It may not be a bug after all and you will get advice how to proceed; developer time is precious and a discussion here in the forum will produce far better tickets; you may be offered a workaround until the bug is fixed.
freman
Postby freman » Sat Oct 12, 2019 3:57 am
Yeah, if shouting doesn't work, shout louder !
Agree with Chris , making it conditional invites folks to ignore it.
cron
