Thank you bernd. it partially works.bernd wrote: ↑Wed Sep 26, 2018 4:59 pm remember volumes of the famous cantilever starts with 149 thusIt seams if the element could not be colored all or non (which means all will be green) elements are colored. BTW the code ... https://github.com/FreeCAD/FreeCAD/blob ... #L178-L192 and https://github.com/FreeCAD/FreeCAD/blob ... #L631-L652Code: Select all
Gui.getDocument("FemCalculixCantilever3D").getObject("Box_Mesh").Visibility=True A=Gui.getDocument("FemCalculixCantilever3D").getObject("Box_Mesh") A.ElementColor={149:(1,0,0)}
Maybe I'm digging too much (sorry for my insistence), but I found another bugs or something that it is not compatible.
Here is a bug 1:
The visibility changes If you select show inner true or show inner false. Volumes are partially showed...
FreeCADGui.getDocument("FemCalculixCantilever3D").getObject("Box_Mesh").ShowInner = False
FreeCADGui.getDocument("FemCalculixCantilever3D").getObject("Box_Mesh").ShowInner = True
If you change the display mode to faces + wireframe + nodes
FreeCADGui.getDocument("FemCalculixCantilever3D").getObject("Box_Mesh").DisplayMode = u"Faces, Wireframe & Nodes"
FreeCADGui.getDocument("FemCalculixCantilever3D").getObject("Box_Mesh").PointColor = (0.33,0.33,1.00)
By changing the colors of the materials the cantilever beam becomes a superstar
BTW I have another two question related with this visual handling options:
1-) How can I change the colors of more than one element at the same time? (I think it is not possible...)
2-) How can I return to the original colors of the mesh?
Thank you so much,
best regards,
Ekaitz.
