Gmsh 4 package available for testing in Community Extras PPA
kkremitzki
Re: Gmsh 4 package available for testing in Community Extras PPA
Postby kkremitzki » Fri Oct 05, 2018 10:44 am
bernd wrote:
Fri Oct 05, 2018 9:36 am
wow fast ! Which one should I use best on Debian Stretch ?
Hmm, not sure, but I would hesitate to install one of the .deb files from the PPA. Normally I would recommend just cloning the package source repository (https://salsa.debian.org/kkremitzki-guest/calculix-ccx) and building it but the package is set up in a bit of a strange way that breaks if you don't use git-buildpackage which requires some dotfiles to behave correctly.
If you're feeling adventurous you could try this:
1. Create a file ~/.gbp.conf with these contents: https://wiki.debian.org/PackagingWithGi ... e_gbp.conf
2. Run sudo apt install git-buildpackage
3. Run gbp clone --all https://salsa.debian.org/kkremitzki-guest/calculix-ccx
4. Run cd calculix-ccx && gbp buildpackage -us -uc
Edit: You may also want to modify the ~/.gbp.conf I linked, particularly the postbuild line:
postbuild = lintian -iIE --pedantic $GBP_CHANGES_FILE && echo "Lintian OK""" || echo "Lintian NOT OK" && true
Postby bernd » Sun Oct 07, 2018 5:24 pm
https://launchpad.net/~freecad-communit ... d/15512624 I did not hesitate and gave this a try https://launchpad.net/~freecad-communit ... d/15512624 It worked like a charm :D
I may even give your description with git-buildpackage a try too.
Postby bernd » Sun Oct 07, 2018 5:33 pm
Ahh Kurt there are another two, they work with FreeCAD FEM already but are not available neither for Debian nor for Ubuntu AFAIK.
In FEM we have another two solver Z88 and elmer are outdated in Stretch too ...
Z88
See https://packages.debian.org/stable/z88 Version 13 is years old, really years (for sure more than 5) ... Version 15 is the current one https://en.z88.de/download-z88os/
Elmer has been removed in Debian
https://packages.debian.org/search?keywords=elmer
kkremitzki
Postby kkremitzki » Sun Oct 07, 2018 6:13 pm
Z88
Yes, I knew about Elmer and have been working on it for quite some time. I'm pretty close to having an updated package available for release. I didn't know about the state of Z88 though! I'll add that to the list.
Postby bernd » Sun Oct 07, 2018 6:39 pm
:D
Postby Kunda1 » Tue Dec 04, 2018 6:16 pm
Postby Kunda1 » Wed Dec 12, 2018 3:23 am
Heads up, new release from the Gmsh folks:
From http://gmsh.info/CHANGELOG.txt
Gmsh 4.0.7 (December 9, 2018): fixed small memory leaks; removed unused code.
Postby Kunda1 » Mon Jan 14, 2019 1:21 am
New release:
4.1.0 (January 13, 2019): improved ONELAB and Fltk support in API; improved
renumbering of mesh nodes/elements; major code refactoring.
Postby bernd » Mon Jan 14, 2019 5:46 am
wafi
Postby wafi » Mon Jan 14, 2019 10:20 am
moin
I had a small problem with my computer ... and after more or less rebuilding, nearly everything is working, except FEM and CfD with FreeCAD.
In both cases meshing is not possible, in the FEM WB: Gmsh requires OpenCASCADE to import shape
What I do not understand, Gmsh is newest version: gmsh ist schon die neueste Version (4.0.2+dfsg1-0ppa1~ubuntu18.04)
BUT if I am looking for version number with Gmsh -- version, it is said that version no is 3.0.2 ...?
In CfD WB nearly same trouble, meshing the regions with cfmesh not possible, no failure message, just nothing is going on. I pretty sure that I made a failure, but I not able to find it. Please assist.
OS: Ubuntu 18.04.1 LTS
Version: 0.18.15611 (Git)
Hash: 64a94ae0f7c60fc981086fe157150a9c0dca29c6
Python version: 2.7.15rc1
Qt version: 5.9.5
