Extend python document observer capabilities
ickby
Postby ickby » Mon Oct 08, 2018 6:01 am
Hello,
for a small python project of mine I need some comprehensive document observation capabilities. This is done via document observers, however, some key things are not yet observable. Hence I implemented some additions to the current capabilities:
- Finished recompute for objects and the whole document
- Transactions: open, commit and abort
- onBeforeChange for notifications of properties that are about to be changed
- document property changes
- Add/Remove dynamic properties to objects
- New Gui document observer, for added viewproviders and changes to viewprovider properties
- Start/Finish edit mode of viewproviders
Furthermore I added testcases for all the python document observer capabilities.
Pull request:
https://github.com/FreeCAD/FreeCAD/pull/1707
Regards,
Stefan
microelly2
Re: Extend python document observer capabilities
Postby microelly2 » Mon Oct 08, 2018 6:29 am
Thank you for sharing this, I see nice new possibilities.
damian
Postby damian » Mon Oct 08, 2018 6:32 am
Thank you
+1
DeepSOIC
Postby DeepSOIC » Mon Oct 08, 2018 8:45 am
Nice!
Also wanted:
* aboutToSaveDocument (for save, save-as, save a copy, save on exit, but not for auto backups)
* onDocumentSaved
ickby
Postby ickby » Tue Oct 09, 2018 1:29 pm
Werner merged and also considered DeepSOICs whiches. Thanks!
Postby wmayer » Tue Oct 09, 2018 1:39 pm
There two further slots: slotStartSaveDocument and slotFinishSaveDocument.
In case you have to distinguish between the three save methods then:
* for saveAs you have to use slotBeforeChangeDocument or slotChangedDocument because it notifies you when the FileName property changes
* for saveCopy you can compare the passed file name with FileName. If they are different then saveCopy is invoked
Postby yorik » Tue Oct 09, 2018 1:42 pm
This document observer is becoming a pretty powerful thing... Thanks folks!
Postby Kunda1 » Tue Oct 09, 2018 1:48 pm
Can someone with technical understanding volunteer to document this ?
Postby Kunda1 » Fri Oct 12, 2018 6:20 pm
Opened a request on the FC Dev Blog, anyone interested in contributing ?
https://github.com/FreeCAD/FreeCAD-blog/issues/6
DeepSOIC
Postby DeepSOIC » Fri Oct 12, 2018 6:24 pm
Thanks!
