Texturing Architectural Objects
furti
Postby furti » Fri Oct 19, 2018 10:18 am
Hello :)
I created a Workbench that can be used to texture architectural objects https://forum.freecadweb.org/viewtopic.php?f=9&t=31598.
As @paullee suggested I cross post it here. Hopefully this is OK. Otherwise feel free to remove this topic :)
If you have some feature requests or improvements regarding arch and textures we can discuss it here.
paullee
Re: Texturing Architectural Objects
Postby paullee » Fri Oct 19, 2018 4:12 pm
Hope it is OK and nobody remove it.
Would be good to be included in Add-on, easier for peoples like me to add and use it :) Seem a numbers of audience already!
Also, possible to add shading mode, shadow?
Thanks.
Postby Kunda1 » Fri Oct 19, 2018 4:34 pm
If @yorik gives the green light, I'll add it to the addon-manager
paullee
Postby paullee » Fri Oct 19, 2018 11:11 pm
Thanks!
paullee
Postby paullee » Sat Oct 20, 2018 6:08 pm
I am adding a link to the github of the new workbench here - I am more used to dig thing out in this board :)
https://github.com/furti/FreeCAD-ArchTextures
paullee
Postby paullee » Sun Oct 21, 2018 4:57 pm
Hi I try to follow the Readme... not know where am I do wrong, I get an error...
BTW, I am using:-
FC - FreeCAD-0.17.13541.9948ee4.glibc2.17-x86_64.AppImage
Os - Fedora 27
Screenshot from 2018-10-22 00-53-55.png (213.16 KiB) Viewed 1532 times
furti
Postby furti » Sun Oct 21, 2018 5:14 pm
I only tested with 0.18 and python 3 right now. Got the same error like you with python 2. Maybe you can try a python 3 build too?
Forgot to mention this in the readme :oops:
bitacovir
Postby bitacovir » Sun Oct 21, 2018 5:56 pm
I saw your project here https://forum.freecadweb.org/viewtopic. ... 18#p263618
Wood on windows looks fine.
Is it possible to change the scale of the texture? The walls would look more realistic with a more dense pattern.
Another feature should be to modify the rotation of the texture. In the case of the roofs, an individual orientation of the pattern for each face will help to visualise better the deep of the volumes.
But sure you have already these points in your to-do list.
Just great work.
::bitacovir::
My personal web site
My GitHub repository
My old Blog
Mini Airflow Tunnel Project
furti
Postby furti » Sun Oct 21, 2018 6:36 pm
Yes this is possible by setting the "length" and "height" of the texture. Did the wider pattern on purpose. Schould look a bitore modern. But might change in the future :) thanks for your oppinion :)
The rotation issue is one of the next things on my list :)
paullee
Postby paullee » Mon Oct 22, 2018 10:43 pm
Tried...
- FreeCAD_0.18.14928.glibc2.17-x86_64.AppImage / on Fedora 27
- unfortunately, it seem it is still on Python 2.7.6
- I see... should be using FreeCAD_0.18.14996_Conda_Py3Qt5_glibc2.12-x86_64.AppImage right? Would test again...
So 0.18 would eventually be Python 3, so everything python should be 'upgraded'?
Version: 0.18.14928 (Git)
Python version: 2.7.6
Screenshot from 2018-10-23 06-35-26.png (254.86 KiB) Viewed 1472 times
