Update on the development of the OpenFOAM CFD workbench (CFDOF)
Moderator: oliveroxtoby
Re: Update on the development of the OpenFOAM CFD workbench (CFDOF)
Hi, I would like to report a bug.
All three meshers ignore what you enter as "base element size" since rev.14982. They behave as if you enter 0 and automatically takes a value at the moment you click on "mesh". That was not the case with rev.14928.
Can anybody confirm this?
Edit:
same in rev. 14993
Version: 0.18.14993 (Git)
Hash: 1e6818b6fbf86ad08d8fc85252dddcae8891dd54
Python version: 2.7.14
OCC version: 7.2.0
Edit:
same in rev. 14993
OCC version: 7.2.0
Yes, confirmed. In report view I get
"TypeError: Can't call meta function because I have no idea how to handle Base::Quantity"
when meshing.
system:
OCC version: 7.2.0
- oliveroxtoby
Thank you for reporting this. I'll investigate.shIxx wrote: ↑Thu Oct 18, 2018 11:42 am Hi, I would like to report a bug.
Edit:
same in rev. 14993
OCC version: 7.2.0
- oliveroxtoby
I've created a pull request to revert the commit that caused the issue, so hopefully this will be fixed soon.shIxx wrote: ↑Thu Oct 18, 2018 11:42 am Hi, I would like to report a bug.
Edit:
same in rev. 14993
Using the below with the latest CfdOF WB all is back to normal from the quick tests I've carried out.
OS: Windows 7
Version: 0.18.15043 (Git)
Hash: b11ed19f8d8a658817829df8c3223a24a660afbb
OCC version: 7.2.0
OS: Windows 7
OCC version: 7.2.0
- oliveroxtoby
Great, thank you!
Hi
I've finally got to grips with CFDoF WB. Awesome work that makes OF accessible to non-professionals like me !
There is just one query to speed up my workflow. Is there any way to get the CFMesh to run in parallel ? I have a dual processor Xeon PC with 6 cores per processor running on Kubuntu. At the moment the mesher is only using 1 looking at my System Monitor.
Thanks
Tim
Thanks
Tim
- oliveroxtoby
cfMesh is partially parallelised using OpenMP. If you monitor throughout the run you should find that for some of the time it uses all the cores available whereas at other times only one is used. I haven't done much comparison but another way to run it is in domain decomposition mode (as we do with snappyHexMesh). Not as efficient in the parallelised bits, but would use all processors for the complete process.TimScottz8 wrote: ↑Sat Sep 05, 2020 9:36 am Hi
Thanks
Tim
Thanks for the reply. I did see it using a number of cores at times but only when I stared at the screen for a while
