Cool robot!
call for screenshots - By Yorik
Re: call for screenshots - By Yorik
Did you use the assemlby2 workbench for this?
Cool robot!
Cool robot!
Indeed, the robot looks really cool!
Currently, I'm working on a similar one. It's a six legged robot with a RaspberryPI as its main brain box. I developed a multi channel servo controller based on a cheap ST ARM micro controller board. It's the "famous" blue pill and it supports up to 24 parallel PWM channels with timed signal interpolation (more are possible depending on the number of pins your micro has).
I also wrote a control/simulation software for testing the kinematics of the robot. I don't have a FreeCAD model right now, just some pieces of PVC hard foam sheets for the chassis prototype but this should be enough for some basic tests.
Maybe I'll post some photos here if you want, because this is not directly related to FreeCAD. Hopefully everything will be open source someday
BTW: It seems that this robot uses little dc motors with gear boxes to move each leg. I don't know how he determines the actual joint positions of the robot, but this is essential for a working kinematic system. With servos this is quite simple.
No, that was a "manual" assembly by placing the parts in the right position. I'm trying to learn how to use Assembly3 but haven't got the time for it
Indeed, there is a place for encorder rings and refractory optocuplers to use for that matter. But haven't got the time to work on the electronics for it. My idea was to use an FPGA+hard processor for the control.RickDeckard wrote: ↑Thu Aug 30, 2018 9:31 am BTW: It seems that this robot uses little dc motors with gear boxes to move each leg. I don't know how he determines the actual joint positions of the robot, but this is essential for a working kinematic system. With servos this is quite simple.
0666: read and write access for all!
1st Post! Brand new to FreeCAD and this is my first model. I Just finished it today.
- Screenshot from 2018-11-04 11-34-59.png (285.54 KiB) Viewed 23190 times
Welcome here with a by far not trivial first model.
Thank you! It took me forever to figure out that I can do everything in part design- I originally was trying to use both part and part design and the errors were driving me crazy! I come from SolidWorks and I'm so impressed at how a free software is so powerful. Amazing.
Thanks
Would you care to make a tutorial on this? Especially your perspective coming from Solidworks and how you adjusted to FreeCAD ? We need more documentation of this kind.Celica_Supra wrote: ↑Mon Nov 05, 2018 1:56 pm Thank you! It took me forever to figure out that I can do everything in part design- I originally was trying to use both part and part design and the errors were driving me crazy! I come from SolidWorks and I'm so impressed at how a free software is so powerful. Amazing.
Hi Kunda;Kunda1 wrote: ↑Mon Nov 05, 2018 6:17 pmWould you care to make a tutorial on this? Especially your perspective coming from Solidworks and how you adjusted to FreeCAD ? We need more documentation of this kind.Celica_Supra wrote: ↑Mon Nov 05, 2018 1:56 pm Thank you! It took me forever to figure out that I can do everything in part design- I originally was trying to use both part and part design and the errors were driving me crazy! I come from SolidWorks and I'm so impressed at how a free software is so powerful. Amazing.
Absolutely. I have a YouTube Channel of SolidWorks tutorials and I will start doing some FreeCAD. When I have time I'll upload a wheel tutorial very similar to the one I made here. For reference, my channel is:
youtube.com/c/jokoengineeringhelp
Thanks
Hi Kunda;Celica_Supra wrote: ↑Thu Nov 08, 2018 4:20 amHi Kunda;Kunda1 wrote: ↑Mon Nov 05, 2018 6:17 pmWould you care to make a tutorial on this? Especially your perspective coming from Solidworks and how you adjusted to FreeCAD ? We need more documentation of this kind.Celica_Supra wrote: ↑Mon Nov 05, 2018 1:56 pm Thank you! It took me forever to figure out that I can do everything in part design- I originally was trying to use both part and part design and the errors were driving me crazy! I come from SolidWorks and I'm so impressed at how a free software is so powerful. Amazing.
Thanks
Here it is
https://www.youtube.com/watch?v=7XXnuly ... e=youtu.be
Fantastic!
