kbwbe
Postby kbwbe » Sat Nov 17, 2018 2:21 pm
Hi all,
there is an update of A2plus available, V0.1.7
What's new:
- a new constraint "axisParallelConstraint"
Two axis' are rotated to be parallel, but not moved to be coincident.
It works with linear edges and axis' of cylinder faces.
Have fun !
KBWBE
latest release: v0.4.45c, installable via FreeCAD's addon manager
jbe
Postby jbe » Sat Nov 17, 2018 3:17 pm
Thank you kbwbe
I will test.
kbwbe
Postby kbwbe » Sun Nov 18, 2018 1:43 pm
Hi all,
and the next update of A2plus is available, V0.1.8
Whats new:
- a new "axisPlaneParallel" constraint
An axis (linear edge or axis of a cylindrical face) is aligned parallel to a selected face. But the parts are not moved to be coincident.
Have fun !
Turro75 wrote:ping
Hi Turro,
this was your issue #4, you was waiting for to be solved.
KBWBE
manuelkrause
Postby manuelkrause » Wed Nov 21, 2018 1:24 pm
Hi all,
Whats new:
Have fun !
Turro75 wrote:ping
Hi Turro,
Hi @kbwbe:
When testing FreeCAD_0.18.15221_Conda_Py3Qt5_glibc2.12-x86_64.AppImage with A2plus I get the following:
No module named 'a2p_partinformation'
File "<string>", line 67, in Initialize
Have I made a mistake or someone else?
TIA for a reply :-)
EDIT:
Same when copying in a a2p_partinformation.py from somewhere new.
Now:
No module named a2p_partlistglobals
File "/home/manuel/.FreeCAD/Mod/A2plus/a2p_partinformation.py", line 28, in <module>
from a2p_partlistglobals import PARTLIST_COLUMN_NAMES
/EDIT
kbwbe
Postby kbwbe » Wed Nov 21, 2018 2:41 pm
Hi Manuel,
i downloaded the "FreeCAD_0.18.15221_Conda_Py3Qt5_glibc2.12-x86_64.AppImage" and tested it. A2plus is working for me. There is no errormessage on my side.
Does the file "a2p_partinformation.py" exist within your ModFolder/A2plus ? Or is it deleted somehow ?
KBWBE
manuelkrause
Postby manuelkrause » Wed Nov 21, 2018 3:31 pm
Hi Manuel,
Sorry for bothering,
I've also cross-tested my local vs. your devel.
The Bug is in my "improve-color" code, that I've already had submitted.
Your devel code works well. Meaning, without errors. But also without keeping transparency...
BR, Manuel
kbwbe
Postby kbwbe » Wed Nov 21, 2018 3:45 pm
Now:
/EDIT
Why same ? Your error message changed. Now the file "a2p_partlistglobals.py" is not recognized on your system.
Try deleting all *.pyc files in A2plus folder and start again. These files are automatically created new on restarting A2plus.
On my system, also partlist is running correctly with Conda build AppImage.
Edit: Posts overlapped by time, sorry.
KBWBE
kbwbe
Postby kbwbe » Wed Nov 21, 2018 3:53 pm
Good that it is working for you.
Yesterday, i had a look around again in sourcefiles of recent Assembly2. Perhaps there is something interesting for you regarding transparency. In file "/FreeCAD_assembly2/assembly2/importPart/__init__.py" are code sections commented with "Transparency workaround". Perhaps you can find hints there.
/Edit: filename was wrong...
KBWBE
manuelkrause
Postby manuelkrause » Thu Nov 22, 2018 9:29 am
Now:
/EDIT
Hi Klaus,
thank you very much for trying to help me. And sorry for all that confusion.
With "same" I meant that it's pointing to the same source of error. Namely: On the way of catching up with your devel-branch, by applying your commit patches one by one to my local improve-colors-branch, I've completely messed it up. Actually I'm missing several files (6!) in my improve-colors branch that are in your devel-branch, although I thought to have carefully applied every commit. No idea how I was able to break it. (Maybe untracked new files??)
Is there a known "best practice" to follow, so that I can fix my local and remote branch(es) without confusing the current states in your and my remote trees?
TIA, Manuel
P.S.: Thank you for your hint about assembly2's workaround! I've also noticed it a while ago but haven't completely understood it and thus haven't experimented with it so far. I'll give it a try once I've fixed the current mess... :oops:
manuelkrause
Postby manuelkrause » Thu Nov 22, 2018 12:09 pm
kbwbe wrote: ping
Hi Klaus,
again, sorry for that last confusion with my branch... It was really about untracked files from your newer commits within my local version. I'm still too unexperienced with git... And so, I may have ignored some git (commit) messages in order to add the new files to be tracked.
(I've solved it now, by making a comparison diff to find the 8(!) culprit files, re-clone my tree, and commit the comparison diff to my local and remote branch improve-colors, finally.)
This source of error was quite new to me. Hopefully I'm going to remember it for the next times and I check my files...
Please don't be too angry about this embarrassing waste of time,
Manuel
