#!/bin/bash
apt-get install python-dbg python-pyside2.qtopengl python-setuptools python3-dbg python3-numpy python3-pyside2.qtcore python3-pyside2.qtgui python3-pyside2.qtopengl python3-pyside2.qtwidgets python3-setuptools libsoqt4-dev libsimage-dev
rm -rf mypivy
mkdir mypivy
cd mypivy/
git clone https://salsa.debian.org/kkremitzki-guest/pivy
cd pivy
git archive upstream | gzip > ../pivy_0.6.4.orig.tar.gz
dpkg-buildpackage -us -uc
the error:
$ sudo bash /vagrant/py3pivy.sh
Cloning into 'pivy'...
warning: redirecting to https://salsa.debian.org/kkremitzki-guest/pivy.git/
remote: Enumerating objects: 5731, done.
remote: Counting objects: 100% (5731/5731), done.
remote: Compressing objects: 100% (1683/1683), done.
remote: Total 5731 (delta 3882), reused 5707 (delta 3859)
Receiving objects: 100% (5731/5731), 14.67 MiB | 928.00 KiB/s, done.
Resolving deltas: 100% (3882/3882), done.
fatal: Not a valid object name
dpkg-buildpackage: info: source package pivy
dpkg-buildpackage: info: source version 0.6.4-1
dpkg-buildpackage: info: source distribution unstable
dpkg-buildpackage: info: source changed by Kurt Kremitzki <kurt@kwk.systems>
dpkg-buildpackage: info: host architecture amd64
dpkg-source --before-build .
dpkg-source: info: using options from pivy/debian/source/options: --compression=bzip2 --compression-level=9 --single-debian-patch
dpkg-source: info: using patch list from debian/patches/series
dpkg-source: info: applying fix_python_modules.patch
debian/rules clean
dh clean --with python2,python3 --buildsystem=pybuild
dh_auto_clean -O--buildsystem=pybuild
I: pybuild base:217: python3.6 setup.py clean
running clean
Cleaning headers:.
removing '/home/vagrant/build_FC/pivy/.pybuild/cpython3_3.6_pivy/build' (and everything under it)
'build/bdist.linux-amd64' does not exist -- can't clean it
'build/scripts-3.6' does not exist -- can't clean it
I: pybuild base:217: python2.7 setup.py clean
running clean
Cleaning headers:.
removing '/home/vagrant/build_FC/pivy/.pybuild/cpython2_2.7_pivy/build' (and everything under it)
'build/scripts-2.7' does not exist -- can't clean it
I: pybuild base:217: python3.6-dbg setup.py clean
running clean
Cleaning headers:.
removing '/home/vagrant/build_FC/pivy/.pybuild/cpython3_3.6_dbg_pivy/build' (and everything under it)
I: pybuild base:217: python2.7-dbg setup.py clean
running clean
Cleaning headers:.
removing '/home/vagrant/build_FC/pivy/.pybuild/cpython2_2.7_dbg_pivy/build' (and everything under it)
dh_autoreconf_clean -O--buildsystem=pybuild
dh_clean -O--buildsystem=pybuild
dpkg-source -b .
dpkg-source: info: using source format '3.0 (quilt)'
dpkg-source: info: building pivy using existing ./pivy_0.6.4.orig.tar.gz
tar: This does not look like a tar archive
tar: Exiting with failure status due to previous errors
dpkg-source: error: tar -xf - --no-same-permissions --no-same-owner subprocess returned exit status 2
dpkg-buildpackage: error: dpkg-source -b . subprocess returned exit status 2
