Lanz Bulldog mini tractor
Uses flame eater type Stirling engine.
- Fin 0.JPG (301.96 KiB) Viewed 4163 times
- Fin 1.JPG (117.48 KiB) Viewed 4163 times
- Lanz Engine and Gearbox.JPG (55.42 KiB) Viewed 4163 times
- Lanz Rear Axle Assembly.JPG (62.35 KiB) Viewed 4163 times
Re: Lanz Bulldog mini tractor
Very impressive, thanks for sharing. Call yourself lucky that these engines had only one cylinder - at most!
I also have an 8 cylinder micro Aero engine and a lorry with a 2 cylinder under-slung engine amongst many others which I will eventually post.
Hello, I am building the mini tractor lanz, and I would be very useful freecad project. I would really appreciate it if you send it to my mail via pm.
Reason: removed email from post
FAO axel_sch,
Hi, plans for the Lanz mini tractor can be found here.
http://www.vapeuretmodelesavapeur.com/telechargements4/
Good luck with the project.
Hi, If you cannot locate the plans on previous posted link try this one
http://www.vapeuretmodelesavapeur.com/telechargements5/
