[Solved] getting point on a face.
mfasano
Post by mfasano »
I would like to get the point that shows up on the status bar when you click on a face. I tried
I tried
pos = FreeCADGui.ActiveDocument.ActiveView.getPoint(mouseposition)
I hope you can help
Thanks,
import Part, FreeCAD, PartGui, FreeCADGui
from FreeCAD import Base, Console
#App.newDocument()
#This class logs any mouse button events. As the registered callback function fires twice for 'down' and
#'up' events we need a boolean flag to handle this.
class ViewObserver:
   def __init__(self):
       secondtime = 1
   def subselect(self, info):
       DOWN = (info["State"] == "DOWN")
       left = (info["Button"] == "BUTTON1")
       pixpos = info["Position"]
       pos = FreeCADGui.ActiveDocument.ActiveView.getPoint(pixpos)
       if (left and DOWN):
#             try:
               pre = FreeCADGui.Selection.getPreselection()
               param = pre.SubObjects[0].Surface.parameter(pos)
               FreeCAD.Console.PrintMessage(pre.ObjectName+","+pre.SubElementNames[0]+"\n")
               App.Console.PrintMessage("is and edge " + str(pos)  + "\n")
#           except:
#               App.Console.PrintMessage("Oups"+"\n\n")
actview=Gui.activeDocument().activeView()
o = ViewObserver()
c = actview.addEventCallback("SoMouseButtonEvent",o.subselect)
#  actview.removeEventCallback("SoMouseButtonEvent",c)
ulrich1a
Re: getting point on a face.
Post by ulrich1a »
In most cases I have a look at the properties of an object in the python console.
This revealed the following and should provide the requested Point.
pre=Gui.Selection.getPreselection()
pre.PickedPoints
Ulrich
mfasano
Post by mfasano »
it appears GetPoints gives a tuple of 1 item. It is not a string. I don't know what type it is. for example
points = pre.GetPoints
ponts = (vector (2 ,5, 7),)
how to I extract the point from it . I could convert to a string and parse it.
Thanks,
mfasano
Post by mfasano »
I figured it out. GetPoints returns a tuple of Vectors. so
point = pre.GetPoints
point[0] will be the vector I want.
Thanks,
