High quality draft with 0.18_pre with tutorial
Re: High quality draft with 0.18_pre
Post by Kunda1 »
Really nice work! Keep sharing!!
roerich_64
Post by roerich_64 »
Kunda1 wrote: Sun Dec 02, 2018 12:14 pm Really nice work! Keep sharing!!
Thank you! More from this or from other projects with the same quality?
cheers
Walter
Die Liebe wird siegen, denn sie ist unzerstörbar :) ;)
Post by Kunda1 »
roerich_64 wrote: Sun Dec 02, 2018 8:58 pm Thank you! More from this or from other projects with the same quality?
Both! :D
roerich_64
Ok, here a very close look to the inside of the Motor.
More in the next days ;)
Walter
roerich_64
Kunda1 wrote: Sun Dec 02, 2018 9:04 pm
Both! :D
Next step should be this part of the Drone:
regards
Walter
roerich_64
Has anybody an idea how i can scale an imported *.WRL file?
i came to this point:
When i click ok i can not see the PCB in the view window, but in the tree window i can see the PCB...
OS: Windows 7
Version: 0.18.15273 (Git)
Hash: 4e77cee5ee6efa1b28290c10ccb8b2540b9eecaf
Python version: 2.7.14
OCC version: 7.2.0
regards
Walter
roerich_64
Ok.
I found my own way. It is not what i thought, but it is near what i need:
regards
Walter
Post by Kunda1 »
What did you do? Do we need to file a bug report ?
roerich_64
Kunda1 wrote: Fri Dec 07, 2018 12:58 pm What did you do?
The last picture above: i took the STL file without colors an take the PNG from the WRL to the face of the PCB...
Kunda1 wrote: Fri Dec 07, 2018 12:58 pm Do we need to file a bug report ?
Yes, that was a good Idea... But how can we do this?
I found, the most problem was with the scale-factor of the WRL file.
When i change the scale factor in the WRL file with a text editor, the PCB with the PNG was ok.
But the electrical pieces are not scaled...
Edit:
I have now changed the scale off the peaces with a text editor. But the position was not scaled:
Edit_2: This was the head of the WRL file:
#VRML V2.0 utf8
Transform {
rotation 1 0 0 -1.570796
children [
Transform {
translation 0 0 0.134
scale 0.001 0.001 0.001
children [DEF GRP_pcbgroup Group {
children [
Shape {
appearance DEF COL_element3 Appearance {
material Material { diffuseColor 1 0.843 0 }
geometry IndexedFaceSet {
solid TRUE
coord Coordinate {
point [
633.858 320.866 39.37,
633.067 323.819 39.37,
633.067 323.819 0,
633.858 320.866 0,
Post by Kunda1 »
do you mind using the
[code]
tags to wrap source code. It helps readability and also maintains indentations when necessary. Thanks
