GRBL new post processor with drill cycles G81..G83
Gauthier
Re: GRBL new post processor with drill cycles G81..G83
Postby Gauthier » Wed Dec 12, 2018 9:55 am
Hi all,
Yesterday, I published the Grbl post processor with G81..G83 drill cycles translations on my Github account here : grbl_G81_post
This more efficient updated version (full rewrite) is ready for Python 3 (work in Python 2.7 and Python 3), and it is able to handle the speed units convertion beetwen FreeCAD (mm/s) and Grbl gCode standard (mm/mn).
On this Github, you can also found my Grbl fork: grbl-Mega-5X
This is a Grbl-Mega enhancement wich add the ability to :
  • handle 3 to 6 axis,
  • chose the name of each axis from X, Y, Z, A, B or C,
  • clone one axis name movement to 2 or more motors drivers (by chosing the same name for more than one axis),
Finally, you will also find on my Github account, the cn5X++ control panel, a new 5/6 axis Grbl control panel whose purpose is to implement all the grbl-Mega-5X capabilities...
cn5X ++ is still in active development, but it is starting to be used to drive a CNC mahine.
I hope this will interest the community, and this lay a first stone of 5 axis CNC milling with FreeCAD...
Regards, @++;
Gauthier.
freman
Postby freman » Wed Dec 12, 2018 9:58 am
Thanks for making this work available. 5 axis is part of my aims so this will probably be useful.
sliptonic
Postby sliptonic » Wed Dec 12, 2018 4:09 pm
Hi all,
I've only glanced through the code, not actually tried running it but this looks good. I would suggest preparing a pull request so we can test it formally and discuss merge.
Nice work!
Gauthier
Postby Gauthier » Wed Dec 12, 2018 7:36 pm
Pull request here : https://github.com/FreeCAD/FreeCAD/pull/1837
Gauthier.
freman
Postby freman » Fri Jun 07, 2019 6:03 pm
Did this every get merged? I don't find this in my 0.19 src.
Is the file attached to post #1 here, the current version to use?
thx. ( great work BTW )
Postby chrisb » Fri Jun 07, 2019 11:34 pm
I have grbl_G81 here.
OS: macOS 10.13
Version: 0.19.16822 (Git)
Hash: 243aebf2dfbfe192b5bbd067020a5318a0fa8d0d
Python version: 3.7.3
Qt version: 5.6.2
freman
Postby freman » Sat Jun 08, 2019 5:19 am
Thanks, it was a misunderstanding on my part. I thought this was intended to replace the old "grbl" which does not produce code suitable for GRBL. I did not realise that it had been installed in parallel as a separate post processor. Sorry for the noise.
Gauthier
Postby Gauthier » Sat Jun 08, 2019 7:42 am
Hi @freman,
Latest version of grbl_G81_post (some small bugs corrected and inches conversion option added) is not already merged because I think it need some more test.
See : https://forum.freecadweb.org/viewtopic.php?f=15&t=35208
you can find it alone on my github here : https://github.com/fra589/grbl_G81_post
Thanks to test and report :)
Gauthier.
freman
Postby freman » Sat Jun 08, 2019 8:20 am
thanks, I've dropped that into place, I'll let you know if see anything wrong.
sliptonic
Postby sliptonic » Sat Jun 08, 2019 1:58 pm
What is the rationale for maintaining both a grbl and a grbl_g81 post processor?
Can your work be merged into the main grbl post to avoid confusion?
