Create and display local coordinate system
Zolko
Re: Create and display local coordinate system
Postby Zolko » Tue Dec 18, 2018 7:43 pm
DeepSOIC wrote:
Mon Dec 17, 2018 11:13 pm
BTW, try:
App.ActiveDocument.addObject('App::Placement')
It's a CS frame. But it's not useful, because nothing supports it.
Holy cow, the LCS feature already exists !!!
App.activeDocument().Body.newObject('PartDesign::CoordinateSystem','LCS')
And it looks like an LCS (no arrowheads though, visually it's defined in ~/src/Mod/PartDesign/Gui/ViewProviderDatumCS.cpp), it's selectable, it highlights in the 3D window ... don't know whether it's used though. And I don't know why the creation of datum coordinate systems has not a corresponding button, although there is an icon for it : "PartDesign_CoordinateSystem.svg"
saso
Postby saso » Tue Dec 18, 2018 8:25 pm
And one can actually place datum elements outside the body! :)
App.ActiveDocument.addObject('PartDesign::Plane')
App.ActiveDocument.addObject('PartDesign::Point')
App.ActiveDocument.addObject('PartDesign::CoordinateSystem')
Now if only things would not be jumping out of the Part all the time... :roll:
DeepSOIC
Postby DeepSOIC » Tue Dec 18, 2018 8:42 pm
Nice catch. I wanted to show that one too, but couldn't find it.
It was used for attaching PartDesign primitives back in the early days of 0.17dev. Then, ickby invented Extension mechanism for creating chunks of re-usable functionality, and PD Primitives now use extension-powered attachment directly, and don't need the CS object.
Otherwise, I don't know if this PartDesign::CoordinateSystem is supported by anything.
saso
Postby saso » Tue Dec 18, 2018 9:05 pm
Soooo close to heaven... Elements from Part WB (Sketch, Extrude) and elements from PartDesign WB (Body, Sketch001, Pad) all driven by the same datum plane (PartDesign__Plane) :)
Zolko
Postby Zolko » Tue Dec 18, 2018 9:25 pm
well well well, its time could come : there is my pet problem of making assemblies without constraints, where parts are placed by snapping their respective LCS. Ne messing with parallelisms, concentricities, tangencies.... pure rigid attachment. An LCS might not be the origin (0,0,0), and a part (body) might have several potential attachment points, thus several LCS. Think about a wheel, that could be attached on its axis on either side: needs 2 LCS, and the attachment LCS is selected during assembly.
see @ forum: https://forum.freecadweb.org/viewtopic.php?f=20&t=32843
saso
Postby saso » Tue Dec 18, 2018 10:15 pm
Also axis to axis transform, no problem :)
https://www.youtube.com/watch?v=7-p5lHGIl8A
cs transform.FCStd
(16.87 KiB) Downloaded 40 times
In the animation below I am selecting the datum plane and changing its map mode, but it is possible to do much much more...
Zolko
Postby Zolko » Wed Dec 19, 2018 8:45 am
you're right, that's better, it doesn't need any Body object. It doesn't need any Part object either ... actually, you can add this to any active document. Even better if you name it:
App.ActiveDocument.addObject('PartDesign::CoordinateSystem','LCS_1')
saso
Postby saso » Thu Dec 20, 2018 9:05 am
CoordinateSystem seems functional and usable to me, can it be added to the gui? Please :) At least as the other datum elements in the Part Design to be used in the Body... BUT! What I would find even much much better is if all of them (point, line, plane, cs) would be changed so that they can be used generally (not just in Body), as demonstrated above, and the icons moved from the Part Design Helper toolbar, next to the Part and Group icons in the Structure toolbar :)
Zolko
Postby Zolko » Thu Dec 20, 2018 9:52 am
I agree, and this should be done for the 0.18 release
This can wait for after 0.18 I think
DeepSOIC
Postby DeepSOIC » Thu Dec 20, 2018 10:52 am
BTW, can you list a few actual uses for it?
EDIT: 1. the project above, where stuff is attached to the LCS.
If we are going for it, we at least should provide some compatibility, I think.
