interFoam Error with multiphase flow
Moderator: oliveroxtoby
kix
Postby kix » Sat Dec 22, 2018 3:11 pm
I tried some example in cfdof workbench but it has error with multiphase (air-water) flow model.
I made the model "filling of tank" simililar to https://forum.freecadweb.org/viewtopic. ... 47#p194045
The model is attached.
  • blueCFD-core: installed via freeCAD
  • The calc. conditions are set in cfdof workbench only. I don't edit the openFoam files directly.
  • Mesh/walls seems no problem since the solver runs in single phase flow.
  • Boundary conditions: Inlet= velocity, Outlet= pressure
Can anyone tell me how to fix?
Happy holidays!
log.interFoam:
Create time
Create mesh for time = 0
PIMPLE: no residual control data found. Calculations will employ 3 corrector loops
Reading field p_rgh
Reading field U
Reading/calculating face flux field phi
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
Reading g
Reading hRef
Calculating field g.h
No MRF models present
No finite volume options present
GAMG:  Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors : sum local = 0, global = 0, cumulative = 0
Courant Number mean: 0 max: 0
Starting time loop
Interface Courant Number mean: 0 max: 0
deltaT = 0.0011904762
Time = 0.00119048
PIMPLE: iteration 1
--> FOAM FATAL ERROR:
Only Euler and CrankNicolson ddt schemes are supported
    From function int main(int, char**)
    in file ../VoF/alphaEqn.H at line 49.
FOAM exiting
Version: 0.18.15449 (Git)
Hash: 47a38eceb395887d5cce220ff882f525ca06c4b7
Python version: 2.7.14
OCC version: 7.2.0
testCFD2.FCStd
(26.12 KiB) Downloaded 18 times
thschrader
Re: interFoam Error with multiphase flow
Postby thschrader » Sun Dec 23, 2018 12:11 am
same issue here
Version: 0.18.15399 (Git)
Hash: 9683abfc36c3e9e94b9175428ec9491b869a6b97
OCC version: 7.2.0
thschrader
Postby thschrader » Sun Dec 23, 2018 8:29 am
There is an issue when writing the case.
fvSchemes-dict, line 20 ddtSchemes: default should be Euler.
@kix: after writing the case, edit fvSchemes dict. Solver runs.
kix
Postby kix » Sun Dec 23, 2018 9:15 am
Hi thschrader,
Thank you for the quick response!
I also confirmed the solver runs with the modification :D
I should learn more about openfoam...
oliveroxtoby
Postby oliveroxtoby » Sun Dec 23, 2018 11:18 am
Sorry about that - fixed the bug. Please update your workbench.
