Transient or steady state CFD problem
Moderator: oliveroxtoby
thschrader
Re: Transient or steady state CFD problem
Postby thschrader » Sun Dec 23, 2018 12:10 am
julieng wrote:
Sat Dec 22, 2018 11:22 pm
Thschrader, do you tried my 2D laminar case?
Sorry, I forgot to mention.
Some hints:
with the given parameters v=5 mm/s inlet speed and 100 mm cylinder diameter
you get a vortex frequency of only 0,01 Hz (see definition of Strouhal-Number).
That means: to see one vortex, the simulation time must be at minimum 100 sec.
I increased the speed a little to get 1 Hz, but as I said above, pimplefoam crashed.
thschrader
Postby thschrader » Sun Dec 23, 2018 10:09 am
Same problem as in
https://forum.freecadweb.org/viewtopic.php?f=37&t=32963
After writing the case, edit the fvSchemes-dict an replace
"steadyState" by "Euler".
@julieng: your file runs without crash, but due to the very low inlet speed,
you see no movement.
oliveroxtoby
Postby oliveroxtoby » Sun Dec 23, 2018 11:19 am
thschrader wrote:
Sat Dec 22, 2018 9:56 pm
pimplefoam crashes.
I rebuilt this tutorial
http://www.tfd.chalmers.se/~hani/kurser ... Report.pdf
but both 2D/3D cases dont work. After 30 iterations, pimplefoam stops with error.
tutorial2D.FCStd
tutorial3D.FCStd
Sorry about that. Fixed the bug.
julieng
Postby julieng » Sun Dec 23, 2018 5:10 pm
Ok. My question was to know if the residual error for the pressure was ok because during all the transient simulation p always larger than 0.1
Best regards
thschrader
Postby thschrader » Tue Dec 25, 2018 11:14 am
On my simulations too. I am not sure how to interpret the residuals
when running a transient case (if the flow seems plausible, for me the solution is "good")
you can activate the report-view to see what the solver is doing (view/panels...).
Maybe this helps.
oliveroxtoby
Postby oliveroxtoby » Tue Dec 25, 2018 6:30 pm
Best regards
If the residuals are not reducing by a few orders of magnitude, this is probably an indication that the problem being modelled has a lot of unsteady behaviour and a time-resolved simulation (i.e., transient) may be more appropriate.
I don't understand when I can compute turbulent cfd problems in steady or in transient simulations ? It is impossible to know before the simulation if the flow will be steady or not.
It depends on whether you are trying to determine the time-accurate evolution of the flow field over time (transient simulation) or the steady state flow field that eventually emerges (in which case a transient simulation will get you the answer quicker). But the latter depends on whether the setup actually admits a reasonable approximation to a steady solution.
julieng
Postby julieng » Fri Dec 28, 2018 3:41 pm
Hello, the residual error doesn t decrease during a transient simulation
Best regards
oliveroxtoby
Postby oliveroxtoby » Sat Dec 29, 2018 12:14 pm
Best regards
It won't do unless the flow reaches a steady state.
julieng
Postby julieng » Tue Jan 01, 2019 8:18 pm
Hello
Can you have a look on the model please (the model is attached in a previous named flow pass a cylinder Re 05). The model cannot be more simple but I have always a very high value of the error for pressure even for very low inlet velocity.
Best regards
Happy new year
thschrader
Postby thschrader » Fri Jan 04, 2019 10:27 pm
The flow past a cylinder is always instable.
I have a question to you:
Can you compute the resulting force on the body (your cylinder)?
It is only a cylinder, should be easy.
