Adaptive Path/CAM Operation
Re: Adaptive Path/CAM Operation
Deleting the DatumPlane gives me the same wrong path.
I have created a very simple example showing the issue with a cube and a rectangular pocket. It might help to find the error.
Edit: I replaced model and screenshot after Herbert's comment below.
- adaptive_cb.FCStd
- (33.69 KiB) Downloaded 72 times
- sliptonic
I'm still not able to duplicate the problem on my home machine. I tried updating everything on my work computer and got bit by this issue so I'm hesitant to try the same thing at home.
Maybe you could try a git bisect and figure out when the problem got introduced.
I have tested some old (Mac) versions. I loaded my cubic file from above and performed a recompute:
14802: crash
14827: works.
14915: shows the undesired behaviour from above.
Hope this helps.
14802: crash
14827: works.
Hope this helps.
Hi Chris,
If i delete the job and make it new, at a first look it seams to work.
At a secound look there is a different problem but in my mind made by user...: You made the pocket at the bottom of the cube and create the patn without turning the part upside down, so milling path is createt through the part and leaves that part of it, which should be the pocket...
But i'm in mind that behavior is correct, because milling works "from top to bottom", if i want to mitt out something at the bottom i have to put the bottom to the top first.
OS: "openSUSE Leap 42.3"
Version: 0.18.15481 (Git) AppImage
Hash: 763b5c362fe4b98dca858f86f5d1353075224651
Python version: 2.7.6
Qt version: 4.8.6
atm i try'd only your model. If i open the file you posted i have the "path to nowhere". - And there is a milling path "hole through all" where i dont know where is the hole?
Qt version: 4.8.6
Gruß Herbert
Not sure if I am relieved or worried that others run into the same issue - still no trace of the secret sauce though
EDIT: chrisb's model also fails for me
You are right, I have replaced file and screenshot above, however the issue remains.
I have tried with my Ubuntu version. A recompute fixes the issue. Saving and recompute on the Mac recreates it again.
OS: Ubuntu 16.04.5 LTS
Version: 0.18.15528 (Git)
Hash: 1f30c218e65d605e7306dc82732cb7d83bb6bb00
Python version: 2.7.12
Even if I recompute only the AdaptivePath the issue is toggled. It seems that not only the values of AdaptiveInputState and AdaptiveOutputState change, but also Placements of Z-axis, XZ plane.
