FEM – Sandwich Panel Buckling
HarryvL
Postby HarryvL » Mon Apr 02, 2018 7:17 pm
With reference to the discussion on mixed meshes (https://forum.freecadweb.org/viewtopic. ... 9&start=70), I thought I would do an example where such an option would add much value. Against expectation, I managed to achieve excellent results with existing FreeCAD options and would like to show that here.
I analysed the buckling load of a 1x2 m sandwich panel composed of two 1mm thick aluminium sheets glued to a 5cm thick Polyurethane core. The FreeCAD model for this assembly is shown below. In addition, I add two 5x5x100cm steel blocks at either end of the panel to ensure uniform introduction of loads.
Sandwich Panel Model.png (210.61 KiB) Viewed 905 times
At first I tried to mesh this model with maximum element size of 5 mm, to ensure reasonable aspect ratios for the C3D10 elements in the aluminium cladding, but had to abort the mesh generation after a 30 minutes wait. With a maximum element size of 50mm, the mesh generation only took 5 seconds, but I was convinced that the aspect ratio of 1:100 (see below) would yield rubbish results.
In the INP file I then manually replaced the *STATIC card with a *BUCKLE card and put the Poisson ratio for all materials to zero to prevent lateral contraction and thus avoid sensitivity to lateral constraints in the boundary conditions.
The first buckling mode appears to agree well with that of the classical Euler solution.
However, the buckling load is 4% in error compared to the Euler buckling load, which is rather much for such a fine mesh.
I therefore looked further into the effect of shear deformation; an effect that is normally ignored for slender structures, but that is important in sandwich panels with a soft core. Two simple corrections exist for shear deformation, one by Engesser (1889) that shows agreement within 0.3% of the CalculiX result and one by Haringx (1942) that is even closer, with less than 0.1% error.
So we can conclude that for this particular example, the C3D10 elements with extreme aspect ratios perform well. However, similar results could have been achieved with much simpler meshes based on mixed solid (core) and shell (cladding) elements. I am therefore very much looking forward to this ongoing development.
thschrader
Re: FEM – Sandwich Panel Buckling
Postby thschrader » Mon Apr 02, 2018 8:56 pm
Harry,
thanks for your work you are doing and giving it to the forum.
You are the first who is doing such a systematically work here.
When the replies to your posts come late or none:
the reason is: hard stuff, and much work to understand.
Keep up the spirit!
regards Thomas
jake77
Postby jake77 » Thu Jan 17, 2019 6:30 am
@HarryvL, thank you for the contribution. Could you perhaps submit the .inp file for the buckling calculation?
I'm just starting to use freeCAD and Calculix hoping to solve mainly linear strength and buckling problems. I have extensive experience with ANSYS Classical and I'm not afraid of getting my hand dirty with input macros but I have a hard time finding resources (simple examples e.g. buckling of a beam or a plate) on how the analyses should be defined in CalculiX. :?
Thank you in advance!
jake77
Postby jake77 » Thu Jan 17, 2019 8:41 am
jake77 wrote: Thu Jan 17, 2019 6:30 am @HarryvL, thank you for the contribution. Could you perhaps submit the .inp file for the buckling calculation?
OK I found the way:
replace the line
*STATIC
with the following two lines:
*BUCKLE
X
with X being the number of buckling modes requested.
HarryvL
Postby HarryvL » Thu Jan 17, 2019 10:30 am
Yup. Please let me know if I can be of further help.
jake77
Postby jake77 » Thu Jan 17, 2019 10:57 am
HarryvL wrote: Thu Jan 17, 2019 10:30 am Yup. Please let me know if I can be of further help.
Thanks. I'm fighting my way up the learning curve.
