Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Moderator: oliveroxtoby
Crossleyuk
Re: Computational Fluid Dynamics (CFD) workbench using OpenFOAM
Post by Crossleyuk »
Hi Oliver, Michael Crossley here again.
First off thank you so much for the speedy response and offering me a little more confidence.
I did what you suggest and got no more joy, so started all over again by:
1) uninstalling CFD and CfdOF and reinstalled.
2) removing all the CFD Analysis items from my FreeCAD model Model tab
3) whent through the Elbow tutorial again step by stem taking images of each dialogue boxes as I prgressed
I have prepared a pdf of the sequence and here is a copy that shows an observation that I made in the final image.
MJC Elbow Rev P3 CfdOF Dialogue Sequence - Rev P1.pdf
(228.57 KiB) Downloaded 107 times
My final observation was that it was looking for a folder identified as:
0.3: [Errno 13] Permission denied: 'c:\\users\\user\\appdata\\local\\temp\\meshCase\\Allmesh'
The final folder after meshCase actually changed as I re-ran the analysis and I adding each of the folders in turn. Even after building the folder chain it still failed.
At this point I'm completely out of my space but another observation is that it is reporting double backslashes in the above (c:\\users\\user\\appdata\\local\\temp\\meshCase\\Allmesh').
I have no idea but does this help at all and hope I make sense. Really sorry to trouble you on this and I will leave you in peace if I'm of no help :-) :lol:
But thank you so much, I am enjoying this and love your work !!
thschrader
Post by thschrader »
Crossleyuk wrote: Wed Jan 16, 2019 6:43 pm But thank you so much, I am enjoying this and love your work !!
Hi Michael,
can you run my file on your machine?
It is a 4,5 mm diabolo projectile, fired by an airgun. 2D-case.
I downloaded your simulation. Please check your coordinate system
for inlet/outlet values.
Thomas
diabolo.FCStd
(23.66 KiB) Downloaded 53 times
Crossleyuk
Hey Thomas, thanks for the response. I tried your case and I got the same Analysis control Write result below.
Thomas Diablo Case Analysis Fail.PNG (21.81 KiB) Viewed 1864 times
Sorry, not quite sure what you mean regarding "coordinate system for inlet/outlet values" I haven't seen anything that refers to this other than the original sketch being located at the x, y and z origin. Is it within CfdOF? Is it this in the Data tab?
Thomas Inlet 1 Coordinate System.PNG (13.78 KiB) Viewed 1864 times
Thanks for your patience, I still have a lot of learning to do here. :roll:
oliveroxtoby
Post by oliveroxtoby »
Crossleyuk wrote: Wed Jan 16, 2019 6:43 pm I have prepared a pdf of the sequence and here is a copy that shows an observation that I made in the final image.
Hi Michael
This is a strange one. It seems that the mesh is created successfully. To be clear, does the folder c:\users\user\appdata\local\temp\meshCase exist after you have created the mesh?
Please could you save the entire contents of the Report View when you click the "Mesh" button and "Write" buttons to a text file and attach that here? (You don't have to re-build your case - just click 'Mesh' in the meshing window and 'Write' in the solver window and copy the output that results.)
Crossleyuk
Hello Oliver,
"c:\users\user\appdata\local\temp\meshCase" was not made after running Mesh. I went back and made it manually and when I ran Mesh it added new folders to the failed report each time, resulting in the "0.3: [Errno 13] Permission denied: 'c:\\users\\user\\appdata\\local\\temp\\meshCase\\Allmesh'" report.
Here is a copy of the mesh object and solver report. Is this what you wanted?
Mesh Response To Oliver.docx
(37.74 KiB) Downloaded 63 times
Thanks yet again and I have some more info that I'll get to you later. I tried my own very simple case and got a different result. It'll take me some time to get the info together.
Cheers
Michael
oliveroxtoby
Crossleyuk wrote: Thu Jan 17, 2019 12:55 pm Hello Oliver,
Cheers
Michael
Please could you have a look at this post: https://forum.freecadweb.org/viewtopic. ... 92#p280359 for how to enable the report view. There will be a lot more output on that.
It's really puzzling that you are able to display the mesh in FreeCAD, if the folder doesn't exist. Are you able to view the mesh in paraview?
thschrader
Crossleyuk wrote: Wed Jan 16, 2019 10:52 pm Sorry, not quite sure what you mean regarding "coordinate system for inlet/outlet values" I haven't seen anything that refers to this other than the original sketch being located at the x, y and z origin. Is it within CfdOF? Is it this in the Data tab?
Your inlet vector should be +y at inlet 1 and +z at inlet 2 ;)
thschrader
@CrossleyUK:
meshing works, case writing works.
But some files are broken... strange
thschrader
@CrossleyUK:
I deleted the cfd-analysis and started a new one.
No idea why the error from above happens.
However, this works:
CFD_Tutorial_1_new.FCStd
(33.45 KiB) Downloaded 54 times
on
Version: 0.18.15536 (Git)
Hash: 98ebeaa198df945ba666c15912c6caf95920f0ef
Python version: 2.7.14
OCC version: 7.2.0
Crossleyuk
Hi again Oliver and Thomas,
I woke up with a thought at 02:00 this morning and had to take a look.
I decided to start my own very simple case that is here:
CFD Simple Track - Rev P1.FCStd
(23.46 KiB) Downloaded 52 times
here is the result after Mesh and Solver.
Rev P1 CFD Simple Track Mesh.PNG (33.14 KiB) Viewed 1794 times
Rev P1 CFD Simple Track Solver.PNG (317.32 KiB) Viewed 1794 times
So it seamed to work this time but last night there was a failure report after generating only two iterations.
Great news and helpful I hope and this is telling me just how much I need to learn befor I can use FeeCAD CFD for my research.
Cheers and million thanks guys.
Michael
