FaceBinder: What is meant by the Sew property?
Roy_043
Postby Roy_043 » Sun Jan 20, 2019 6:34 pm
I do not understand what is meant by the Sew property of a FaceBinder. Changing it seems to have no effect?
Re: FaceBinder: What is meant by the Sew property?
Postby wmayer » Sun Jan 20, 2019 6:57 pm
If there are e.g. two faces inside a compound that visually share an edge then in the topology there are still two edges. The sew operation changes the topology to share sub-shapes where needed. The operation may also result in changing the shape type.
Example code:
import FreeCAD
import Part
f1=Part.makePlane(10,10,FreeCAD.Vector(0,0,0))
f2=Part.makePlane(10,10,FreeCAD.Vector(10,0,0))
shape=Part.Compound([f1,f2])
shape.ShapeType
#Compound
len(shape.Edges)
#8
shape.sewShape()
shape.ShapeType
#Shell
len(shape.Edges)
#7
Roy_043
Postby Roy_043 » Sun Jan 20, 2019 9:44 pm
Thanks for your explanation. I think I understand on a theoretical level, but would there be a FaceBinder example where this would have a visible effect?
Postby NormandC » Mon Jan 21, 2019 12:13 am
Example code:
Being an absolute neophyte at Python, I can't get this to work. I tried adding
from FreeCAD import Part
from FreeCAD import Base
I still get errors that FreeCAD.Part has no attribute 'makePlane' nor 'Compound'.
Edit: nevermind, I loaded the Part workbench and this fixed it. :oops:
Postby wmayer » Mon Jan 21, 2019 9:34 am
I fixed the code to explicitly import Part.
