SQL Reporting Workbench for FreeCAD
Re: SQL Reporting Workbench for FreeCAD
Postby yorik » Mon Jan 14, 2019 4:33 pm
wow,VERY interesting! I'm also not happy with the arch schedule tool. This indeed is extremely more powerful.
paullee
Postby paullee » Wed Jan 16, 2019 1:14 am
Another amasing works after the Arch Texture WB!
Can't wait to try unfortunately I have no acess to a PC right now.
Hope there is also some quantity surveyor joining the discussion about Bill of Quantity / Material etc.
furti
Postby furti » Wed Jan 16, 2019 7:20 pm
I'm glad to here that there is some interest in such a tool :)
I updated the repository with the first Basic implementation of a report. (still no documentation yet)
The tool works a bit like the "Arch schedule" tool.
Open a document and start the "Reporting" workbench.
This will create a Report Object in the document for you. Each Report object has a spreadsheet attached that stores the result of the report.
Double click the Report Object to add some queries to it.
For the sample file attached in the initial post i used this statement:
Select Label, HorizontalArea
From document
Where IfcRole = 'Column'
When you click "OK" the report is executed. Now open the Spreadsheet and you should see a result like this
You can use multiple Statements per report. And you can skip the Header field if you don't Need one.
Maybe some of you could already test it and give me feedback about the general workflow.
Also intersting to me is: Are there any properties that need special tostring handling (e.g. for quantities i use the UserString property. Everything else is simply converted to a string with pythons "str" method)
Happy reporting ;)
furti
Postby furti » Fri Jan 18, 2019 8:26 pm
I updated the Readme with a short tutorial and the SQL Reference.
The SQL parser also supports grouping now. :)
Postby Kunda1 » Sat Jan 19, 2019 12:12 pm
Hey @yorik
@furti opened a request to add this WB to the Addon repo
furti
Postby furti » Sat Jan 19, 2019 4:13 pm
Added some bugfixes and minor improvements. Also started a "How To" section in the Readme where I want to collect some useful SQL Statements that might be of interest for others too :)
See https://github.com/furti/FreeCAD-Report ... es/tag/0.1 for more Details.
furti
Postby furti » Wed Jan 23, 2019 7:59 pm
Added some new Features and redesigned the Report Config UI a bit.
See https://github.com/furti/FreeCAD-Report ... es/tag/0.2 for more Details.
Postby yorik » Thu Jan 24, 2019 1:53 pm
Added to the addons manager!
I'll need to have a look at integrating it with the BIM WB... :)
furti
Postby furti » Thu Jan 24, 2019 4:51 pm
Awesome :)
This would be pretty nice. I think the Report is already a good replacement for the arch schedule tool :)
furti
Postby furti » Sat Jan 26, 2019 11:44 am
Added Export / Import commands to the workbench. This makes it possible to share Reports between different Projects or create a report library with common used Reports. :)
For a full list of changes see https://github.com/furti/FreeCAD-Report ... es/tag/0.3
cron
