Command panel
Re: Command panel
Is any possibility to extend as global panel?. useful for me to use array in other workbenches.
Re: Command panel
Yes. Global panel mode was already implemented and will therefore get released soon. After "UUID/Domain functionality", as Global panel mode uses it.jaisejames wrote: ↑Wed Jan 09, 2019 5:26 am Is any possibility to extend as global panel?. useful for me to use array in other workbenches.
Command Panel
I have found the command panel to be a very nice customization feature. It can show you most functions in FC and access them with just one click. However, noticed some unusual behaviour.
Command panel icons move when open a sketch or use other function:
I am wondering if anyone else has seen this behavior?
Thank you, Jerry/jrdrukin OS: Windows 10
Version: 0.18.15639 (Git)
Hash: 3f51e25b26ed19a2b17e218c8a0d438eb2e13b26
Python version: 2.7.14
OCC version: 7.2.0
OCC version: 7.2.0
Re: Command panel
ShortCuts module for FreeCAD. I do imagine frequent users will likely prefer to set a single key (global) shortcut.
P.S. Jerry thanks for testing and reporting back. I noticed such behavior in the past myself, but didn't yet investigate any possible solutions. Will bump the priority.
There is now a possibility to use a dock widget or an invokable menu. As a container for commands. Invoke shortcut for menu container can be customized with P.S. Jerry thanks for testing and reporting back. I noticed such behavior in the past myself, but didn't yet investigate any possible solutions. Will bump the priority.
Re: Command panel
Support for basic domain name system got implemented. Here is how a typical domain name for a menu looks like when created by:
Developer:
User:
Edit menu section in Preferences got updated and started utilizing domain name system support:
Developer:
CPMenu.System.PartWorkbench.PartSolids
CPMenu.User.StartWorkbench.89315827-0826-4a49-9181-3a888f20e8d9
Re: Command panel
Sometimes it is desired, to use the same set of commands through all workbenches. Global panel mode now provides such capability.
Re: Command panel
Hello, I was testing this command panel for better familiarity. I like it but i may be missing something out in it's understanding. I tried to add the survey and addon manager in the top tool bars as a test to get started with but it didn't work. What am I missing?
Another question I have is that, how do you recognise if any of these dialog windows are made 1. with Qt designer (if yes is there a template?) and or 2. is made with Python? 3. Made with C++?
- Screenshot from 2019-02-04 16-48-00.png (287.52 KiB) Viewed 1740 times
Re: Command panel
Soon an API is to be added. A set of predefined commands and menus for individual workbench will therefore became a possibility. In addition, when no such definitions will be provided, by developer, some commands will get extracted from the workbench toolbars. As a convenience, to always see some commands by default. That didn't yet happen and ATM you get an empty Commands panel by default as the result.regis wrote: ↑Mon Feb 04, 2019 9:53 pm Hello, I was testing this command panel for better familiarity. I like it but i may be missing something out in it's understanding. I tried to add the survey and addon manager in the top tool bars as a test to get started with but it didn't work. What am I missing?
Therefore what you need to do next is to set a default menu for BIM workbench (or globally if Global panel mode is enabled). You can do that by clicking on a checkbox, located left from the menu combo box (Default).
There is no documentation available yet, but as Command panel is nearly done, that will get sorted out after. In addition it's nice to get such feedback, as i get a sense of what potential end users find intuitive or not.
In general you i guess need to take a look in the code for clues. For example:Another question I have is that, how do you recognise if any of these dialog windows are made 1. with Qt designer (if yes is there a template?) and or 2. is made with Python? 3. Made with C++?
https://github.com/triplus/CommandPanel
No C++, no .ui files just Python (and PySide).
Re: Command panel
Thanks a bunch. Still testing. Will give you my feedback at somepoint but so far I like it and it think it is pretty usefull already.
By the way is there a General Icon Bank somewhere? I see alot of people on their individual macro or WB create a seperate folder for icons.
Re: Command panel
You're welcome.
For default set of modules:By the way is there a General Icon Bank somewhere? I see alot of people on their individual macro or WB create a seperate folder for icons.
https://www.freecadweb.org/wiki/Artwork
from PySide import QtGui
btn = QtGui.QToolButton()
icon = QtGui.QIcon(":/icons/freecad")
btn.setIcon(icon)
btn.show()
After updating command panel to the latest changes this should improve.
