assembly without solver
fosselius
Re: assembly without solver
Post by fosselius »
Zolko wrote: Sun Jan 27, 2019 9:08 pm
Haha, was actually working on this, have so far only created a listView containing labels for all Bodies in all open files, got stuck in a movie halfway through..
from PySide import QtGui, QtCore
# Our main window will be a QListView
list = QtGui.QListView()
list.setWindowTitle('Import Link')
list.setMinimumSize(200, 400)
# Create an empty model for the list's data
model = QtGui.QStandardItemModel(list)
textInput = QtGui.QLineEdit(list)
# Find all PartDesign::Body inside all open documents
for documents in App.listDocuments().values():
	for body in documents.findObjects("PartDesign::Body"):
		print body.Label
		item = QtGui.QStandardItem(body.Label)
	    # Add a checkbox to it
		item.setCheckable(False)
	    # Add the item to the model
		model.appendRow(item)
def on_item_changed(item):
    # If the changed item is not checked, don't bother checking others
    if not item.checkState():
        return
    # Loop through the items until you get None, which
    # means you've passed the end of the list
    i = 0
    while model.item(i):
        if not model.item(i).checkState():
            return
        i += 1
    app.quit()
def on_text_changed(text):
	#todo filter on text
	print text
model.itemChanged.connect(on_item_changed)
textInput.textChanged.connect(on_text_changed)
# Apply the model to the list view
list.setModel(model)
# Show the window and run the app
list.show()
Zolko
Post by Zolko »
fosselius wrote: Sun Jan 27, 2019 9:54 pm
Haha, was actually working on this, have only created a listView containing labels for all Bodies in all open files
if you can manage to do it all in 1 dialog, and not like me have 2, it would be much better.
fosselius
Post by fosselius »
Zolko wrote: Sun Jan 27, 2019 9:58 pm if you can manage to do it all in 1 dialog, and not like me have 2, it would be much better.
That was my goal, but that wont be done today. maybe tomorrow, depends on how the day turns out.
realthunder
Post by realthunder »
Zolko wrote: Sun Jan 27, 2019 9:08 pm Now ... about that expression thingy ... would it be possible to store / retrieve the placement expression from an object in the assembly document ? Specifically, an App::Placement, as used here ( App.ActiveDocument.addObject( 'App::Placement' ) ) has a property called "Expression Engine", but that is frozen. Would it be possible to use that property to store the text of the expression ? The field is frozen and empty, but it would be the ideal place to store the string used in the expression engine. (populating the text of that expression is then another subject, but using it would be very natural). Do you know if there is a way to use the field "Expression Engine" in an App::Placement ? Or if it's possible to add another field / property / whatever that could store text, which could be evaluated by the expression engine ? This App::Placement would then become, de facto, the constraint for the corresponding App::Part.
Very object has this "ExpressionEngine" property. This is how you can bind an expression to calculate the placement of an object based on others. If you want to actually use an expression to calculate the placement of an App::Placement object, then
pla = App.ActiveDocument.addObject( 'App::Placement' )
pla.setExpression('Placement', expression)
On the other hand, if you want to store expression text in App::Placement for use by other object, then it is better to add some string type property of your own. I have just added python binding object for App::Placement so that you can do just that. Please sync LinkStage3.
pla = App.ActiveDocument.addObject('App::PlacementPython')
# This '=1' below is necessary to make a python binding object visible.
# In fact this is how FC lets user create their own types, by attaching a user defined Python object to 'Proxy'.
# pla has 'Proxy' too. But for simplicity sake, we are not creating a full fledged python binding here. So just
# assign any thing to ViewObject.Proxy to activate it.
pla.ViewObject.Proxy = 1
pla.addProperty('App::PropertyString','Text')
pla.Text = expression
You can write an expression that accepts parameter, and later calls it when actually binding to some object using eval. If you can't get it work, please provide a file with your exact intention (like which property of which object binds to what expression, etc.), and I'll give it a try.
Zolko
Post by Zolko »
realthunder wrote: Sun Jan 27, 2019 11:59 pm Please sync LinkStage3.
ah yes, that ... you mean this git-thing, don't you ? Until now, I've downloaded a ZIP of your branch and compiled it. To actually set-up a GIT branch (clone / repository / account / thing) on my computer, I'll have to look how to do that. I'm better with a screwdriver than with a keyboard.
fosselius
Post by fosselius »
class ExampleModalGuiClass(QtGui.QDialog):
	def __init__(self):
		super(ExampleModalGuiClass, self).__init__()
		self.initUI()
	def reloadList(self):
		self.model.clear()
		self.bodyList = []
			objectList = documents.findObjects("PartDesign::Body")
			objectList += documents.findObjects("App::Part")
			#print documents.Label
			for body in objectList:
				#print documents.Label + " " + body.Label
				self.bodyList.append(body)
				item = QtGui.QStandardItem(documents.Label + "->" + body.Label)
				item.setIcon(body.ViewObject.Icon)
				self.model.appendRow(item)
	def initUI(self):
		self.list = QtGui.QListView(self)
		self.list.move(10,40)
		self.setWindowTitle('Create Link')
		self.setMinimumSize(400, 400)
		self.model = QtGui.QStandardItemModel(self)
		self.list.setMinimumSize(380, 300)
		self.textInput = QtGui.QLineEdit(self)
		self.textInput.setMinimumSize(380, 0)
		self.textInput.move(10,10)
		self.reloadList()
		self.linkNameInput = QtGui.QLineEdit(self)
		self.linkNameInput.setMinimumSize(200, 0)
		self.linkNameInput.move(10, 350)
		#create link button
		# toggle visibility button
		self.createLinkButton = QtGui.QPushButton('Create Link', self)
		self.createLinkButton.setAutoDefault(False)
		self.createLinkButton.move(210, 350)
		self.model.itemChanged.connect(self.on_item_changed)
		self.textInput.textChanged.connect(self.on_text_changed)
		self.createLinkButton.clicked.connect(self.onCreateLink)
		self.list.setModel(self.model)
		self.list.show()
	def onCreateLink(self):
		print "create link"
		#for item in self.model.data():
		#	print item
		selected = self.list.selectedIndexes()
		for sel in selected:
			itemSelected = self.model.item(sel.row()).text()
			document,body = itemSelected.split('->')
			print "import " + body + " from " + document
				# create the App::Link to the previously selected model
			#App.activeDocument().getObject('Model').newObject( 'App::Link', linkName ).LinkedObject = model
				# create an App::Placement for that object
			#App.ActiveDocument.getObject('Constraints').newObject( 'App::Placement', 'PLMT_'+linkName )
	def on_item_changed(self,item):
			return
		i = 0
		while self.model.item(i):
			if not self.model.item(i).checkState():
				return
			i += 1
	def on_text_changed(self,text):
		self.reloadList()
		filteredText = self.model.findItems(text,QtCore.Qt.MatchFlag.MatchContains)
		if len(filteredText):
			self.model.clear()
			for label in filteredText:
				self.model.appendRow(label)
form = ExampleModalGuiClass()
form.exec_()
A slight update, still needs lots of love.
Zolko
Post by Zolko »
fosselius wrote: Mon Jan 28, 2019 10:49 am A slight update, still needs lots of love.
nice, looks promising. I like the dynamic filter. Meanwhile ...
setting all those LCS-s is time consuming, but once it's done it becomes quite usable. The edit of the expression is the painful part now. And then, I thought about that script that generates bricks ... Couldn't it include an option to place LCS-s automagically on the fixation spots ? Did you manage to make it work ? I didn't.
asm_Lego.zip
(209.61 KiB) Downloaded 71 times
fosselius
Post by fosselius »
Zolko wrote: Mon Jan 28, 2019 12:18 pm The edit of the expression is the painful part now. And then, I thought about that script that generates bricks ... Couldn't it include an option to place LCS-s automagically on the fixation spots ? Did you manage to make it work ? I didn't.
I have not looked at it yet. will let you know if/when i do.
Just updated the previous post. added an element of style ;)
also, if you want a bit more variation, i have my other lego bricks here:
https://gitlab.com/maidenOne/freecad_le ... ster/Parts
And latest import script is here:
https://gitlab.com/maidenOne/freecad_le ... nk.FCMacro
Note, its not yet functional, but its close.
Zolko
Post by Zolko »
realthunder wrote: Sun Jan 27, 2019 11:59 pm if you want to store expression text in App::Placement for use by other object, then it is better to add some string type property of your own. I have just added python binding object for App::Placement so that you can do just that. Please sync LinkStage3.
yes, that would work ... but would it make it into mainline ?
// Python feature ---------------------------------------------------------
namespace App {
PROPERTY_SOURCE_TEMPLATE(App::PlacementPython, App::Placement)
template<> const char* App::PlacementPython::getViewProviderName(void) const {
   return "Gui::ViewProviderPlacementPython";
template class AppExport FeaturePythonT<App::Placement>;
This is a useful functionality, but quite an ad-hoc hack, don't you think ? If it was my money, I wouldn't bet on this horse. May-be as a general purpose feature that allows to add custom text fields to the properties of any object, through Python ... in the file ~/src/App/PropertyContainerPyImp.cpp there is :
int PropertyContainerPy::setCustomAttributes(const char* attr, PyObject *obj)
or in PropertyPythonObject.cpp
void PropertyPythonObject::setPyObject(PyObject * obj)
    Base::PyGILStateLocker lock;
    aboutToSetValue();
    this->object = obj;
    hasSetValue();
Zolko
Post by Zolko »
an App::Placement is also an App::GeoFeature
PROPERTY_SOURCE(App::Placement, App::GeoFeature)
and App::GeoFeature has GeoFeaturePyImp.cpp
int GeoFeaturePy::setCustomAttributes(const char* /*attr*/, PyObject* /*obj*/)
    return 0;
couldn't this be used ? I don't think that modifying the general App::Placement will be accepted. Either there is already a way to add custom fields/objects, and then it can be used, or a custom placement should be coded, derived from App::Placement but enhanced by useful fields/objects, and this enhanced Placement (Link::Placement ?) should be used for assembly. Actually, if this is meant to become the placeholder for constraints, having a purpose-built App::Placement derivative could make sense.
Of course, I have no idea how to actually code that.
