VTK Error
Zig_mint
VTK Error
Postby Zig_mint » Mon Jan 28, 2019 2:20 pm
I am trying to compile from the source code of freecad on ubuntu 16.04. there seems to be some problem with the cmake or VTK.........i am new to this and so have no clue what to do. I am trying to build out of source. here is the attached error and CMakeoutput.log and CMakeerror.log
the terminal output on running cmake <source-code> is
-- Compiler: GNU, version: 5.4.0
-- prefix: /usr/local
-- datadir: data
-- docdir: doc
-- includedir: include
-- libdir: /usr/local/lib
-- cmake: 3.5.1
-- Boost version: 1.58.0
-- Found the following Boost libraries:
-- filesystem
-- program_options
-- regex
-- system
-- thread
-- chrono
-- date_time
-- atomic
-- Found Xerces-C: /usr/lib/x86_64-linux-gnu/libxerces-c.so
-- PyCXX found:
-- Headers: /home/zigmint/freecad-code/src
-- Sources: /home/zigmint/freecad-code/src/CXX
-- Version: 6.2.8
-- -- OpenCASCADE Community Edition has been found.
-- -- Found OCE/OpenCASCADE version: 6.8.0
-- -- OCE/OpenCASCADE include directory: /usr/lib/x86_64-linux-gnu/oce-0.17/../../../include/oce
-- -- OCE/OpenCASCADE shared libraries directory:
CMake Error at CMakeLists.txt:670 (find_package):
Could not find a package configuration file provided by "VTK" with any of
the following names:
VTKConfig.cmake
vtk-config.cmake
Add the installation prefix of "VTK" to CMAKE_PREFIX_PATH or set "VTK_DIR"
to a directory containing one of the above files. If "VTK" provides a
separate development package or SDK, be sure it has been installed.
-- Configuring incomplete, errors occurred!
See also "/home/zigmint/freecad-build/CMakeFiles/CMakeOutput.log".
See also "/home/zigmint/freecad-build/CMakeFiles/CMakeError.log".
CMakeOutput.log
(49.92 KiB) Downloaded 75 times
CMakeError.log
(2.66 KiB) Downloaded 77 times
sgrogan
Re: VTK Error
Postby sgrogan » Mon Jan 28, 2019 11:31 pm
Do you have libvtk6-dev installed?
FreeCAD's CMake is looking for the file: /usr/lib/cmake/vtk-6.2/VTKConfig.cmake
"fight the good fight"
Zig_mint
Re: VTK Error
Postby Zig_mint » Tue Jan 29, 2019 5:22 am
Thank you, for helping out.
I realized libvtk6-dev was not installed...........I installed this package but now when I run the command cmake on the source code I get the following error. I also wanted to know how did you figure this out if possible!!!!!!
-- The imported target "vtkRenderingPythonTkWidgets" references the file
"/usr/lib/x86_64-linux-gnu/libvtkRenderingPythonTkWidgets.so"
but this file does not exist. Possible reasons include:
* The file was deleted, renamed, or moved to another location.
* An install or uninstall procedure did not complete successfully.
* The installation package was faulty and contained
"/usr/lib/cmake/vtk-6.2/VTKTargets.cmake"
but not all the files it references.
-- The imported target "vtk" references the file
"/usr/bin/vtk"
-- VTK components: vtkCommonCore;vtkCommonDataModel;vtkFiltersVerdict;vtkIOXML;vtkFiltersCore;vtkFiltersGeneral;vtkIOLegacy;vtkFiltersExtraction;vtkFiltersSources;vtkFiltersGeometry;vtkIOMPIParallel;vtkParallelMPI;vtkhdf5;vtkRenderingCore;vtkInteractionStyle;vtkRenderingFreeType
-- Check for medfile (libmed and libmedc) ...
CMake Error at cMake/FindMEDFile.cmake:46 (MESSAGE):
med.h not found, please install development header-files for libmedc
Call Stack (most recent call first):
CMakeLists.txt:706 (find_package)
CMakeOutput.log
(49.92 KiB) Downloaded 82 times
CMakeError.log
(2.66 KiB) Downloaded 78 times
kkremitzki
Re: VTK Error
Postby kkremitzki » Tue Jan 29, 2019 5:36 am
Now you need libmedc-dev. You should try running the command sudo apt build-dep freecad. If that doesn't work you may need to edit your /etc/apt/sources.list file and uncomment the appropriate deb-src line.
