Iterate over Mesh Groups
joee
Post by joee »
I would like to script a FE analysis and by using the python interface.
My model is very simple:
  • Body
    • Pad
    Analysis
    • FemConstraintFixed
      FemConstraintForce
      SolidMaterial
      FEMMeshGmsh001
In the console I get the mesh and its part instance by the following commands:
> analysis = App.ActiveDocument.Analysis
> mesh = analysis.getObject("FEMMeshGmsh001")
> part = mesh.Part
Then I would like iterate over all the mesh groups like in the function get_group_data of the class GmshTools (see https://github.com/FreeCAD/FreeCAD/blob ... ls.py#L249), but the array is always empty.
When I start Gmsh via the GUI, the shape2mesh.geo file is written and it contains the group data, so the boundary conditions/mesh groups are defined right. Has anyone an idea what I'm doing wrong?
Thanks in advance!
joee
Re: Iterate over Mesh Groups
Post by bernd »
would you post the FreeCAD file and the python code to reproduce your empty list?
Post by bernd »
Which FreeCAD version do you use. For FEM you should use 0.18 dev version.
joee
Post by joee »
Hi Bernd,
I downloaded the latest 0.18 dev version and tried again, but with no luck.
These are the commands i run after opening the file (see attachment):
>>> mesh = analysis.getObject("FEMMeshGmsh")
>>> mesh.MeshGroupList
Thanks!
ExampleMeshGroup.FCStd
(99.11 KiB) Downloaded 28 times
Post by bernd »
sure your list is empty, because you do not have defined groups for your mesh. You need to define them with the GUI or by Python ... Attached your file with two groups and some python code to get the data ... Do not forget to remesh if you define groups.
code
App.ActiveDocument.FEMMeshGmsh.MeshGroupList
App.ActiveDocument.FEMMeshGmsh.FemMesh.GroupCount
App.ActiveDocument.FEMMeshGmsh.FemMesh.Groups
App.ActiveDocument.FEMMeshGmsh.FemMesh.getGroupElementType(0)
App.ActiveDocument.FEMMeshGmsh.FemMesh.getGroupName(0)
App.ActiveDocument.FEMMeshGmsh.FemMesh.getGroupElements(0)
output
>>> FreeCAD.open(u"/home/hugo/Desktop/ExampleMeshGroup_bernd1.FCStd")
>>> App.setActiveDocument("ExampleMeshGroup_bernd1")
>>> App.ActiveDocument=App.getDocument("ExampleMeshGroup_bernd1")
>>> Gui.ActiveDocument=Gui.getDocument("ExampleMeshGroup_bernd1")
[<Fem::FeaturePython object>, <Fem::FeaturePython object>]
2
(0, 1)
'Face'
'FEMMeshGroup'
(191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260)
(89.73 KiB) Downloaded 28 times
joee
Post by joee »
Thank you!
I thought mesh groups are implicitly created for FE boundary conditions. Can you tell me in which function/file the mesh groups for boundary conditions are being created when running GmshTools? Because in this class the mesh groups are present...
Post by bernd »
Ahh yes this should work if it is activated ...
- FreeCAD preferences --> FEM --> General --> create mesh groups for reference shapes --> activate it
- load your file
- acitvate the analysis
- remesh
- FemMesh groups will be created
- run code
code
outpus
6
(0, 1, 2, 3, 4, 5)
'Node'
'FemConstraintFixed_Nodes'
(1, 2, 7, 8, 9, 10, 11, 12, 13, 80, 81, 82, 83, 84, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474, 475, 476, 477, 478, 479, 480, 481, 482, 483, 484, 485, 486, 487, 488, 489, 490, 491, 492, 493, 494, 495, 496, 497, 498, 499, 500, 501, 502, 503, 504, 505, 506, 507, 508, 509, 510, 511, 512, 513, 514, 515, 516, 517, 518, 519, 520, 521, 522, 523, 524, 525, 526, 527, 528, 529, 530, 531, 532, 533, 534, 535, 536, 537, 538, 539, 540, 541, 542, 543, 544)
MeshGroupList is zero, because this is a user created object to greate FemMesh groups.
