FreeCAD does not import colors for IFC form Allplan
Postby bernd » Fri Jan 18, 2019 1:26 pm
Allplan has two exporter, attached a green column exported with each of the exporters. FreeCAD does not read the colors. Both are grey. I may have a look myself, but this will probably not happen before a release 0.18. To much to do in FEM ...
Version: 0.18.15572 (Git)
Hash: ab1f4c442d443adae106a2ea1ed877f33db86154
Python version: 3.6.6
Qt version: 5.6.2
Locale: German/Switzerland (de_CH)
gruen_new.ifc
(8.6 KiB) Downloaded 22 times
gruen_old.ifc
(5.58 KiB) Downloaded 29 times
Re: FreeCAD does not import colors for IFC form Allplan
Postby yorik » Fri Jan 18, 2019 5:54 pm
this file follows a scheme I hadn't seen before (the IfcStyledItem doesn't say which item it styles)... There is a quite complex system in that file, with drafting styles. We should open a mantis issue for this so we dont forget
Postby bernd » Thu Jan 31, 2019 3:02 pm
Postby bernd » Wed Feb 27, 2019 3:00 pm
Postby bernd » Tue Oct 06, 2020 12:15 pm
git commit 2d1f6ab1a22 fixed the problem of the first post.
Postby bernd » Tue Oct 06, 2020 12:21 pm
new problems. If the new Allplan exporter and IFC4 is used the import breaks ...
OS: Windows 10 (10.0)
Version: 0.19.22522 (Git)
Hash: d8e476ef428017900dfe0f9359ba448503c216f9
Python version: 3.8.5
Qt version: 5.12.6
Coin version: 4.0.0
OCC version: 7.4.0
14:19:45  Opening 'C:/Users/BHA/Desktop/new_exporter_IfC4.ifc'... done.
14:19:45  Building types and relationships table...
14:19:45  More than one 'Style' in 'IfcStyleItem', do nothing.
14:19:45  done.
14:19:45  Parsing 2 BIM objects...
14:19:45  1 / 2 object #89 : IfcSite (arch) no brep : Diverses
14:19:45  2 / 2 object #166 : IfcColumn no layer found IfcColumn (arch) 2k 1 solids : Stuetze
14:19:45  Processing Struct relationships...done
14:19:45  Processing Arch relationships...
14:19:45      adding 1 object(s) to Diverses
14:19:45      adding 1 object(s) to Project
14:19:45  Creating materials...Traceback (most recent call last):
  File "C:\0_BHA_privat\progr\FreeCAD_0.19.xxxxx-Win-Conda\Mod\Arch\ArchMaterial.py", line 297, in onChanged
    c = tuple([float(f) for f in obj.Material['DiffuseColor'].strip("()").strip("[]").split(",")])
  File "C:\0_BHA_privat\progr\FreeCAD_0.19.xxxxx-Win-Conda\Mod\Arch\ArchMaterial.py", line 297, in <listcomp>
<class 'ValueError'>: could not convert string to float: 'None'
14:19:45  Traceback (most recent call last):
  File "C:\0_BHA_privat\progr\FreeCAD_0.19.xxxxx-Win-Conda\Mod\Arch\importIFC.py", line 1303, in insert
    col = tuple([float(f) for f in string_color.strip("()").split(",")])
  File "C:\0_BHA_privat\progr\FreeCAD_0.19.xxxxx-Win-Conda\Mod\Arch\importIFC.py", line 1303, in <listcomp>
new_exporter_IfC2x3.ifc
(6.04 KiB) Downloaded 4 times
(5.99 KiB) Downloaded 4 times
Postby bernd » Tue Oct 06, 2020 12:31 pm
the origin of the problem is a color table with None ectries: https://github.com/FreeCAD/FreeCAD/blob ... FC.py#L351
Eventually the color string is "None" which is impossible to be converted in a FreeCAD color. But it is intended to write None ... https://github.com/FreeCAD/FreeCAD/blob ... er.py#L375
Which means adaption here is needed: https://github.com/FreeCAD/FreeCAD/blob ... 1264-L1269 the None will be written into "DiffuseColor" attribute of material objects material dict.
Postby bernd » Tue Oct 06, 2020 3:19 pm
git commit 8292664f4943
colors for IFC4 export of Allplan are still not imported, because they all are None returned, but at least they do not break the import.
Postby bernd » Tue Oct 06, 2020 4:46 pm
https://github.com/FreeCAD/FreeCAD/blob ... er.py#L458
# Never seen an IFC with more than one element in `Styles`
this is true for IFC2x3 but not for IFC4 ...
IFC2x3 example from above
#116= IFCSTYLEDITEM(#97,(#107),$);
#107= IFCPRESENTATIONSTYLEASSIGNMENT((#109,#112));
#109= IFCCURVESTYLE($,#110,$,#111);
#112= IFCSURFACESTYLE('_hb_n_btl_be_beton_188',.BOTH.,(#114));
IFC4 example from above
#141= IFCSTYLEDITEM(#131,(#143,#146),$);
#143= IFCCURVESTYLE($,#144,$,#145,$);
#146= IFCSURFACESTYLE('_hb_n_btl_be_beton_188',.BOTH.,(#148));
Postby bernd » Tue Oct 06, 2020 5:41 pm
