SQL Reporting Workbench for FreeCAD
Re: SQL Reporting Workbench for FreeCAD
Added "CONCAT" function and fixed a bug with unhashable types in Statements with a "GROUP BY" clause.
Full list of changes is here https://github.com/furti/FreeCAD-Report ... es/tag/0.4
this is amazing! thank you so much. i can't play with it right this second, but i've been hurting for a basic database, and having it inside FreeCAD will be perfect for me.
have you given any thought to creating basic "TABLE", "VIEW", and "REPORT" python object types? obviously i can add whatever i want to my own python object. i need to go read your docs before i ask too many questions.
my main message here is thank you
There is a report object available in the workbench. You can add multiple queries to it an it will fill a spreadsheet with the resulting data.
If you need more specialised objects feel free to make a issue (or even a pull request ) in the github repo. Or post your wishes here.
Currently I'm thinking of a "visibility" object. You configure it with a "Where" clause and it will display or hide all objects matching. I often need this in my current arch project when displaying only a single building part or the whole building.
i'm with you on the visibilty filter.
i need to assign master / derived / construction / final statuses to points, curves and segments of curves, and surfaces and their segments.
right now i do it by choosing a principal charateristic, and sticking the elements in folders. whenever the principal charateristic doesn't map to a specific task, i do a lot of dancing around from folder to folder.
so i want to 'select' all master elements, make then visible / invisible for editing. at the very end, i want to 'select' all final surface segments, and stitch a shell and make it a solid.
by analogy to Solidworks and Autodesk Inventor, i want one autopopulated folder that shows all solids, one for surfaces, one for curves, one for points, etc.
the relational database model is exactly what is needed!
Added Arithmetics and Named columns to the SQL parser
Full list of changes can be found here: https://github.com/furti/FreeCAD-Report ... es/tag/0.5
Hi I install in AddManager
Start FC and find below message, can't find Reporting WB in the drop-down menu.
Any idea?
FreeCAD_0.18.15860.glibc2.17-x86_64.AppImage
on
Fedora 29
Any idea?
During initialization the error No module named report_utils.resource_utils occurred in /home/paullee/.FreeCAD/Mod/Reporting/InitGui.py
on
Fedora 29
Is this a python 3 build? If not, can you give it a try with a python 3 build?
I only use python 3 so this is not tested with python 2
Hopefully we can drop python 2 support soon
I see
Downloaded
FreeCAD_0.18.15823_Conda_Py3Qt5_glibc2.12-x86_64.AppImage
and Reporting WB is there, thanks!
Downloaded
- wandererfan
Just fooling around a bit so far. Reports go onto TechDraw pages easily! Well done @furti!
- ReportOnTDPage.png (202.13 KiB) Viewed 2684 times
Nice to see that. So it schould be pretty easy to export and print them next to the model
