Newbie: Strange behavior
Stonefire
Re: Newbie: Strange behavior
Post by Stonefire »
Ok - thanks...
This is the latest file...
Sincerly
Steen
openBrain
Post by openBrain »
Stonefire wrote: Wed Feb 13, 2019 2:18 pm Ok - thanks...
Sincerly
Steen
Missing attachment. ;)
Stonefire
Post by Stonefire »
sorry
Stonefire
Post by Stonefire »
hmmm
MoTag 12d.FCStd
(826.7 KiB) Downloaded 21 times
openBrain
Post by openBrain »
Here is the clue I have ATM.
I mark all the design for recompute and after recomputing, I see that 4 of the sketches can't be actually updated (they are marked with the blue check mark).
They match with the ones with the red arrow in the Dependency Graph.
The remarkable thing is that when you hover the sketches with the mouse in the combo view, those 4 sketches are displayed as "Touched" in the status bar while others are "Valid". Unfortunately I don't know what exactly it could mean.
I tried to enter the sketches, fully constrain them and force an update but it doesn't solve the problem.
Deeper investigation :
It seems that I guess right and that FC sees a cyclic dependency. Here the message in the Report Panel :
App::Document::recompute(): cyclic dependency detected
Document::recompute(): Sketch206 still touched after recompute
Document::recompute(): Sketch196 still touched after recompute
Document::recompute(): Sketch203 still touched after recompute
Document::recompute(): Sketch241 still touched after recompute
EDIT : lot of typos :oops:
openBrain
Post by openBrain »
Actually it seems it comes from sketch mapping issues.
I dirtily remapped all troubling sketches and they can recompute.
I guess that you mapped sketches to faces that are somewhat dependent on the sketches themselves, creating cyclic dependency.
You have to review your mapping to attach sketches to origin planes (eventually with offset), to datum plane, or only to preceding faces. ;)
Stonefire
Post by Stonefire »
Hi OpenBrain
Ok- Thanks - I'll try to do that...
Sincely
Steen
GeneFC
Post by GeneFC »
OK, here is how to get back to a good starting point.
Several of the sketches have some sort of bad reference or self-reference, as shown in the Dependency Graph. For each of those sketches follow these steps.
1. Select sketch and then go to menu item Part Design >> Reorient sketch
Reorient 1.png (267.03 KiB) Viewed 733 times
2. "Sketch has support" prompt will come up
Click "Yes".
Reorient 2.png (14.38 KiB) Viewed 733 times
3. If the sketch has a reference, good or bad, the next prompt will come up. Click "Cancel". If there was no reference, that window will not show up.
Reorient 3.png (16.35 KiB) Viewed 733 times
4. The Dependency Graph is now clean. You can proceed to rebuild your model by positioning and attaching sketches correctly.
Gene
Stonefire
Post by Stonefire »
Hi OpenBrain
Sincely
Steen
Stonefire
Post by Stonefire »
Hi
Now I think I'm getting somewhere ;-)
No red arrows no more... ;-)
Have made a new loft - made a clone of it and placed it correctly...when making a cut I cant move it into the body without it change direction...
I need it inside the body to extrude new parts onto it....I've tried but the result is on the original loft-part ...and not on the cut-part...
Sincerly
Steen
3.FCStd
(403.4 KiB) Downloaded 18 times
