- start FC
- use the Part WB
- use menu Edit -> Preferences -> Import-Export -> STEP
- there write into the 'author' field text with an umlaut, e.g. 'stöhr"
- press Apply
result: FC freezes. There is no output in the message panel. Finally one has to kill FC because it is not responding and unusable, no matter how long you wait. It seems to be an unfinished loop because the FC uses the full CPU power of one CPU core as soon as you press Apply.
There is no but if there is no umlaut in the author field. Interestingly other non-ASCII characters don't trigger the freeze, e.g. using 'µ' or '³' work. However since my name contains an umlaut I want to use it of course. If this is not possible FC must tell me about and prevent the input of not allowed character.
Version: 0.18.15860 (Git)
Hash: 3b708c7f84b0425076b520e1d95627b20fd75fe0
Python version: 2.7.14
OCC version: 7.2.0
FC freezes when editing export STEP preferences
Re: FC freezes when editing export STEP preferences
I confirm on
OS: Ubuntu 18.04.2 LTS
Python version: 2.7.15rc1
Qt version: 5.9.5
Locale: French/Canada (fr_CA)
Qt version: 5.9.5
Here also. I get the same result using an 'ä'. So despite I didn't try all possible letters, I would suspect the umlaut/trema to be the culprit.
git commit 7d0e06c96 makes sure that only 7-bit ASCII can be entered.
Thanks for having a look. I reported this now as issue #3835.
Wow, you are fast! Many thanks.wmayer wrote: ↑Thu Feb 14, 2019 11:07 am git commit 7d0e06c96 makes sure that only 7-bit ASCII can be entered.
