datum plane creation is unintuitive
uwestoehr
Re: datum plane creation is unintuitive
Post by uwestoehr »
wmayer wrote: Wed Feb 13, 2019 6:32 pm When you create a datum plane then you must already have created a body beforehand...
Many thanks! This make it much more clear. Since I have now Wiki access to write the a2plus documentation, am I also allowed to transfer things I learned here directly to the corresponding Wiki page?:
https://www.freecadweb.org/wiki/PartDesign_Plane
bejant wrote: Wed Feb 13, 2019 8:14 pm I wonder if, to avoid confusion, when the user selects an object having a local coordinate system that is different than the world coordinate system, a secondary X,Y,Z axis indicator should also appear in the lower right corner (next to the existing world X,Y,Z indicator) that shows the local X,Y,Z axes of the selected item? When the object is de-selected this secondary indicator disappears.
That would be very helpful.
bejant
Post by bejant »
uwestoehr wrote: Wed Feb 13, 2019 11:55 pm Since I have now Wiki access to write the a2plus documentation, am I also allowed to transfer things I learned here directly to the corresponding Wiki page?:
Sure!
uwestoehr
Post by uwestoehr »
bejant wrote: Wed Feb 13, 2019 11:58 pm
uwestoehr wrote: Wed Feb 13, 2019 11:55 pm am I also allowed to transfer things I learned here directly to the corresponding Wiki page?:
Sure!
Done.
Pauvres_honteux
Post by Pauvres_honteux »
uwestoehr wrote: Wed Feb 13, 2019 11:55 pm ... transfer things I learned here directly to the corresponding Wiki page:
Reading that page gave me hickup on this sentence "A datum plane is only sensible when there is at least a body."
Shouldn't it read: "As of now [todays date] sadly enough, datum planes can only be created inside a body."?
Pauvres_honteux
Other than that I totally agree with you about the wording used in everything involving placement and especially this "Z-axis is always in the direction of movement".
I would suggest the following:
For offsets there are ONLY two direction, one way or the opposite way, with respect to its origin.
This is how we humans think of an offset in general, i.e. it shall be reflected accordingly in the UI.
Further, we (the users) would, eagerly, like to se this visually in real time in the 3D view port.
Even further, I'd like to ask the coders if it would be possible to create a general, realtime, preview "thingie" easy to use for all programmers anywhere in the code?
HarryGeier
Post by HarryGeier »
It´s very easy :
phpBB [video]
harry
uwestoehr
Post by uwestoehr »
Many thanks for your help and the fruitful discussion. As result the Wiki page was improved and for the remaining proposal I created issue #3836.
bejant
Post by bejant »
To view any local coordinate axis in Part Design, select a Plane or a planar Face and click this icon (in the Part Design Helper toolbar, next to the Create Datum Plane icon):
https://www.freecadweb.org/wiki/PartDes ... nateSystem
It's in my 0.18 version of FreeCAD but not in 0.17.
OS: Ubuntu 18.04.1 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.18.15780 (Git)
Hash: f94e76c1116ec3b818961ff65131b3d86fa5b95e
Python version: 2.7.15rc1
Qt version: 5.9.5
run_the_race
Post by run_the_race »
meme2704 wrote: Wed Feb 13, 2019 4:26 pm Hi
Nothing more simple, When you select "New sketch", you have a small window that appears to choose in which plane (XY, XZ, or YZ) you also "Offset": if you type 5 the new plan will be 5mm at above the origin
If you have a number of sketches, that all need to be at the same height, you want to specify that height in one place (one source of truth), not everytime you make a sketch. Yes you could use spreadsheets, but would be ideal if you could set a plane in the XY 5mm above origin. I also can't figure this out and thats why I'm reading this thread.
run_the_race
HarryGeier wrote: Thu Feb 14, 2019 10:30 am It´s very easy :
phpBB [video]
harry
This is very helpful thank you!! :D . Its easy when you know how. This is not something the majority of people can figure out. As a newb, its a strange concept that to make a plane offset from the origin, it *has* to be linked to an existing object. I kept thinking there is no object I want to link it too!!! Intuitively you would think it does not need to be linked to anything, and that's where most of us are caught out.
