Is there a way to speed up "Detail view"
freedman
Postby freedman » Fri Feb 15, 2019 9:38 pm
It takes about a half hour to set up a Detail view. Every time I move the focus a recompute kicks off. My recomputes seem to be taking a lot longer as I add pages. I tried turning off auto update but then I can't see what I want but I presume when I finish a page, turn off update. Any pointers on making this go faster, ways to deal with the future when I have 10 pages.
Thank you
wandererfan
Re: Is there a way to speed up "Detail view"
Postby wandererfan » Sat Feb 16, 2019 2:43 pm
I've never noticed Detail to be particularly slow vs other types of View. If you can, please post you file and I'll have a look.
TD is slow for some shapes. Usually it is the Hidden Line Removal algos in OCC. OCC announced at one point that they were working on implementing parallel processing for HLR, but I haven't heard of any progress since. That would help a lot.
We could really use something like a painter's algorithm for rendering, but AFAIK it doesn't exist in OCC.
freedman
Postby freedman » Sun Feb 17, 2019 10:49 pm
Here is the threaded part.
Create view, from button press to view; 55 sec.
Create detail, from button press to view; 32 sec.
Move anchor from 0 to .1, from button press to view; 40 sec.
File open with page; 55 sec.
File open without page; 2 sec.
new_created_thread.FCStd
(756.25 KiB) Downloaded 20 times
wandererfan
Postby wandererfan » Tue Feb 19, 2019 1:59 pm
It isn't the Detail view that is slowing things down;
original file - 43.8 sec to load
Log: TIMING - Detail GO spent: 513.222 millisecs in HLRBRep_Algo & co
Log: TIMING - Detail GO spent: 6.280 millisecs in hlrToShape and BuildCurves
Log: TIMING - Detail DVP spent: 11.487 millisecs in GO::extractGeometry
Log: TIMING - ProjItem GO spent: 17155.471 millisecs in HLRBRep_Algo & co
Log: TIMING - ProjItem GO spent: 7.116 millisecs in hlrToShape and BuildCurves
Log: TIMING - ProjItem DVP spent: 27.349 millisecs in GO::extractGeometry
no detail - 38.4 to load
Log: TIMING - ProjItem GO spent: 17860.170 millisecs in HLRBRep_Algo & co
Log: TIMING - ProjItem GO spent: 9.524 millisecs in hlrToShape and BuildCurves
Log: TIMING - ProjItem DVP spent: 28.903 millisecs in GO::extractGeometry
The HLR routines are taking approx 17-18 second to process "ProjItem" (Front) and it gets computed twice.
If I use a regular View instead of a ProjectionGroup, View is only executed once, so the load is faster.
no detail, using View - 22 to load
Log: TIMING - View GO spent: 18054.734 millisecs in HLRBRep_Algo & co
Log: TIMING - View GO spent: 9.812 millisecs in hlrToShape and BuildCurves
Log: TIMING - View DVP spent: 30.207 millisecs in GO::extractGeometry
So the lesson 1 here seems to be don't use ProjectionGroup when a regular View will do.
Lesson 2 is that we need a new geometry builder for cases where we aren't interested in hidden lines.
freecad-daily
OS: Linux Mint 19
Version: 0.18.15860 (Git)
Hash: 3b708c7f84b0425076b520e1d95627b20fd75fe0
Python version: 2.7.15rc1
Qt version: 5.9.5
Locale: English/Canada (en_CA)
wandererfan
Postby wandererfan » Mon Mar 11, 2019 1:29 pm
Could you repeat your timing test with the current version, please? It seems somewhat faster here. Want to make sure it's not just wishful thinking.
Thanks.
freedman
Postby freedman » Tue Mar 12, 2019 7:04 am
Not sure about what file I used so I downloaded the file from the post above for the speed test. I have V18.15991 and v18.16085 installed.
V18.15991 .......... v18.16085
Open file:.....55 sec..........53 sec.
delete detail.
Add detail:.....32 sec...........5 sec.
Move detal anchor:.....33 sec...........4 sec.
delete proj. and detail
Create proj:.....54 sec...........26 sec
Big improvements on:
add detail, 32 sec to 5 sec.
Move detail anchor 33sec. to 4 sec., this is great!
Create projection 54 sec. to 26 sec
Nice!
I'll start using that tomorrow morning. It's hard to make a chart in a post, Spaces and Tabs don't hold.
Thanks
Jee-Bee
Postby Jee-Bee » Tue Mar 12, 2019 7:47 am
Thanks
use code blocks ;)
                    V18.1599    v18.16085
Open file:          55 sec.     53 sec.
delete detail.
Add detail:         32 sec.     5 sec.
Move detail anchor: 33 sec.     4 sec.
Create proj:        54 sec.     26 sec
wandererfan
Postby wandererfan » Tue Mar 12, 2019 1:13 pm
Awesome. Glad it wasn't just wishful thinking.
Postby chrisb » Tue Mar 12, 2019 1:50 pm
Wow! And Thank you!
