uwestoehr wrote: ↑Sat Feb 16, 2019 6:53 pm
Therefore FC can also directly apply angular constraints between all segment lines instead of the datum circle.
I would not want to see the datum circle replaced. For the special case of a hexagon the circle radius is the same as the length of a single leg. Easy to go back and forth. However for other shapes, such as a pentagon or a heptagon that trivial conversion does not exist.
Yes, I do use the pentagon and heptagon at times.
I am not sure there is a one-size, fits-all solution here. Many different users will have many different needs. I consider those prebuit polygons to be just starting points, similar to lines or arcs. It will not be easy (or perhaps not even possible) to make an "improvement" that will work for everyone.
If you want to move the entire shape just grab the center and drag it. No need for any other operation. If you want to distort the shape in some manner then an automatic capability is unlikely to work.
Gene
