FEM documentation missing on the Wiki
Re: FEM documentation missing on the Wiki
Postby bernd » Mon Mar 19, 2018 11:49 am
How it goes:
- the file https://github.com/FreeCAD/FreeCAD/blob ... kbench.cpp defines the FEM commands. They start with FEM_XXXX
- any of the commands there should have a wiki page with exact the same name as the command
- The links to these pages are created in a template. See https://www.freecadweb.org/wiki/Template:FEM_Tools
- I udated the template a few days ago. Any command from the workbench file should have a link in the template which directs to a wiki page.
- ATM lots of this pages could be empty.
- In the templates some commands have wrong icons. The icons are in https://github.com/FreeCAD/FreeCAD/tree ... rces/icons . If an icon is saved as file on the wiki it should be linked on https://www.freecadweb.org/wiki/Artwork ... es.5CIcons Afterwards it could be used in the template.
What needs to be done? What is most important?
- check if every command from https://github.com/FreeCAD/FreeCAD/blob ... kbench.cpp is on the template and has its wiki page.
- Replace the wrong icon links on the template with the right one. If an icon is missing add it to the wiki and include it in the artwork.
Postby bernd » Mon Mar 19, 2018 5:22 pm
svg icons should be used in the template in above post! In artwork all FEM icons are in svg.
Postby bernd » Mon Mar 19, 2018 7:47 pm
fixed most of the icons too.
The pages needs content --- :)
OakLD
Postby OakLD » Tue Mar 20, 2018 4:03 pm
How it goes:
All right, I think I get all the points and I can access all the resources mentioned. I believe I'll get used to that in a bit of time and do the documentation up to expected standards :-)
I tried to use the icons the same way they were used elsewhere in WIKI, it worked, but I understand your point with SVG. I tested SVG icon with the first icon on hand (found the SVG from the page you provided a link) and it worked, so when I have a bit of time, I'll update all of them.
I'll go also slowly through the WIKI list of commands you provided (which I figured out myself, I was just confused that here in this thread is a list of different WIKI pages) and see what I could complete. Some stuff is same/similar in all the software (like Ansys, CalculiX, SolidWorks), but some might be specific to FreeCAD.
As for the specific stuff, I wasn't able to figure out what are used detailed display optoins for, in the pipeline scale dialog: Style (Flow|Zero) and Visibility (Out grayed|Out invisible) - those did not made any apparent differences in the case of the simple test models I tried them with.
Regards,
Oak
Postby bernd » Tue Mar 20, 2018 6:40 pm
done already :)
mhh I do not know exactly either. But this should be discussed in a separate new topic.
Postby Kunda1 » Thu May 31, 2018 12:24 am
bernd wrote:ping
Any plans for issue #3052 ?
Postby Kunda1 » Wed Dec 19, 2018 12:18 pm
Postby bernd » Wed Dec 19, 2018 3:42 pm
What's this a new version of Artwork ?
uwestoehr
Postby uwestoehr » Wed Feb 27, 2019 11:01 pm
I added at least few sentences about the new FEM features in 0.18:
https://www.freecadweb.org/wiki/Release ... _Workbench
and
https://www.freecadweb.org/wiki/Release ... l_Handling
Bernd, could you please write some more since you know what the news are?
uwestoehr
Postby uwestoehr » Wed Mar 13, 2019 12:16 am
and
Ping!
